I can't figure out for the life of me how to remove the headlight assembly. I'm sure it's because I'm an idiot but could someone point me in the right direction?
There is a spring clip on the top mount, grab it with a set of vise grips, twist L to R as your pulling up. take it easy, they are easy to break. after that one, look down behined the rad. support you will see the bottom mount. Slip a 9/16 boxed end wrench over the clip and it should slip right out.
they are the stock ones, i bought mine from this same guy. they look a whole lot better than the 99-02 style about the same brightness, maybe a little brighter
matt
Extremely easy to install, and yes they do look great. Installed mine in less than 30 minutes. The hardest part of the install is locating the two screws under the parking lights, I'm 6'4" and I had to bend doen to see them. Really, they are easy to put in, I bought mine from the Ford dealer, I think they were about 260 - 280 for both, then bought the clear corners from ebay 15 bucks. Hope this helps......
