lift question. please help.
Old Oct 23, 2012 | 01:31 PM
JUSTICE1736's Avatar
JUSTICE1736
i just picked up a 1977 f150 custom. its running 36x12.50r15 super swamper tsl. its got at least a 4 inch block in the back. im wondering what size lift it has on it. i was told it was six inches. so i ordered a 4 inch because i didnt want to buy 36 inch tires and wanted to actually get in it without a running start. and i had a set of 35 inch tires and wheels that fit.
im wondering did i mess up when i bought the 4 inch rough country lift? it only comes with 2 inch blocks cus your supposed to retain the factory blocks. unfortunatly idont have the factory blocks. what are some of yalls suggestions?
Old Oct 23, 2012 | 04:25 PM
lafermedavid's Avatar
lafermedavid
lift
take some pics if you can.
Old Oct 23, 2012 | 04:37 PM
JUSTICE1736
this is the best i have right now. but ill get some more today while im working on it.
Old Oct 25, 2012 | 08:57 PM
NW 150's Avatar
NW 150
I don't have any suggestions for you, but I will say that your truck has the perfect height, stance, and tires. I wouldn't change it IMO. If I were you I would have just gotten some U steps, those small ones that don't look half bad. Then again that's if I were you. I'm 6'1" and just "hop" in lol.
Old Oct 28, 2012 | 10:37 PM
JUSTICE1736
so i just got around to taking some pics of the rear lift blocks. here they are.
Old Oct 28, 2012 | 11:15 PM
fordrealdrive's Avatar
fordrealdrive
Those look like the factory 3" blocks to me.
I'd say you have a 6" kit with rear lift springs on the factory block.
You do realize that going from a 36" tire to a 35" only drops the truck ½" and 2" less lift puts the tires that much farther up in the fenderwells?
Old Oct 28, 2012 | 11:21 PM
HIO Silver's Avatar
HIO Silver
Confirmed... that's a factory block. The inboard wing is a bumpstop. It likely has a spring lift.
The lift and tires look good. I'd leave it as-is.
Old Oct 29, 2012 | 12:25 AM
JUSTICE1736
yeah i know, im not going to be using it for offroading. mainly a hardware store runner and something to add to the collection. ive always wanted one of these trucks and finally could afford getting one to work on. i got 315/75r16 general grabber at2 on american racing ion polished wheels. right now i think im gonna leave it as it is for the lift because im afraid that if i stick the 4 inch in there the back will be sitting lower than the front making it look weird. i prefer the level look of it right now but the swampers were junk and the wheels are rusted.
Old Oct 29, 2012 | 12:29 AM
JUSTICE1736
are the rear springs the same for a 2wd as they are for the 4wd? cus ive got quite a few 2wd trucks in the junk yard that are being parted out, along with a '78 f250.
Old Oct 29, 2012 | 12:29 PM
JUSTICE1736
bump. can anyone help me with that one?
Old Oct 29, 2012 | 05:14 PM
fordrealdrive
½ton 2wd's have 2½" wide rear springs ¾ & 1ton 2wd's got 3" wide rear springs unless its a super camper special or cab/chassis DRW, these have 2½" wide rear springs.
All 4wd's have 3"wide rear springs accept the '67-'77.5 F250's (hi-boys) and they have 2½" rear springs.
Old Oct 29, 2012 | 05:23 PM
JUSTICE1736
ok so i need to find a 3/4 ton 2wd and those should work on a 1/2 ton 4wd?
Old Oct 29, 2012 | 05:47 PM
fordrealdrive
Yes they'll work but why are you wanting to swap a stock leaf pack in the rear?
You'd have a truck that's stock height in the rear and lifted 6" in front...unless your taking all the lift out....
Old Oct 29, 2012 | 05:58 PM
JUSTICE1736
i have a 4 inch lift i already bought thinking id just bolt it in. i wanted something a little milder and not quite so tall. and would fit the tires i have for it better. but since everyone says i have a 6" lift spring pack in the rear and 6 inch lift in the front. then my only choice is to swap out the rear spring or order a pack from rough country. which is nearly 250 bucks. i dont want a monster truck just a good looking 4x4. it probably wont see much offroad use other than checking cows and driving in the pasture so no need for 36 inch super swampers.
this tends to be what i do with my trucks. give them a mild lift and some larger tires. my current 2010 f150 has a two inch leveling kit, and 275/70r18 inc wheels. slightly larger than stock
Old Oct 29, 2012 | 06:25 PM
fordrealdrive
Alright that makes sense now... btw very nice looking truck you have there.
