Sponsored by: Real Truck
2012 F450
Old Oct 23, 2012 | 09:18 AM
fugly 75's Avatar
fugly 75
2012 F450
I know this has been discussed to death!! But, I can't find exactly what I'm looking for as far as info goes. I'm looking at a new F450 4x4. I have a horse trailer that weights around 28,000lbs loaded. I know I probably need to get the actual nose weight of trailer, but my question is should I even be considering a F450 for this heavy of a trailer or should I be looking bigger? What about getting a trailer that size stopped? The Ford's don't have what I would consider an actual exhaust brake. Is anyone out there hauling a trailer this big with a new F450?? I'm looking for actual experience!! Thanks!!!!
Old Oct 23, 2012 | 09:40 AM
Flyinstroke's Avatar
Flyinstroke
I have done that with a F350 many times. Just make sure your trailer brakes are in good working order. Air bags helped the 350 out quite a bit but i dont think the 450 would have a problem with that at all. I usually tip the scales at around that once a month or so hauling cattle across the south. just remember that when you over load the truck you will have to repair it more than some one who doesnt. just my 2 cents
Old Oct 23, 2012 | 10:51 AM
redford's Avatar
redford
FTE Leadership Emeritus
Max rating on the F-450 is 24,500. You are a bit over that.
Will it tow the load? Yes, it will, but I recommend going bigger.
Old Oct 23, 2012 | 11:14 AM
fugly 75's Avatar
fugly 75
Thanks!!!
I was worried about the total weight and also the nose weight of the trailer.
Anyone else have any personal experience???
Old Oct 24, 2012 | 05:23 AM
glsurratt's Avatar
glsurratt
I've got a 2011 F-450, the fiver weighs 21,000 lbs with 4,000 lbs of pin weight. I had to put airbags on it.
Previously, I towed the same weight with an F-350 and was about 3,000 lbs over gross. There's a comfort factor there and that much over the ratings exceeds the comfort factor - I wondered what was going to break first, I couldn't maintain freeway speed on the smallest hills.
Go bigger!
DocB
All Things Towing
18
Feb 16, 2012 01:27 PM
Chris_ce
All Things Towing
Jan 18, 2007 08:03 AM
Ferguson65
All Things Towing
Nov 29, 2006 06:54 PM
D.S.
Sep 27, 2004 08:16 PM
tjbog
All Things Towing
Dec 2, 2002 11:46 PM
