Heavy Red Flow
Old Oct 22, 2012 | 09:23 PM
audion77's Avatar
audion77
Heavy Red Flow
Thought I should start a new thread for an unrelated issue with some leakage I seem to be having.
Noticed after a long trip home and a few days of quick sprints around town I had a lot of fluid in the driveway. Threw a cardboard box under to catch some and it is puddled up Red.
I can see fluid all around the outer edge of the pan and it is wet to the touch. It drips right off the center low point however and is not "dripping" from the edges.
I tightened all the bolts but noticed one was "secure" but not "tight" and wouldn't tighten up much more. This also seems to be the place from where the most fluid is built up around the edge.
I guess I give it a day or two with the tightened bolts then on to a gasket? Anything else I should check?
I should also mention I cannot start it for a few days until i figure out whats up with the fuel pump/no gas getting to the engine. (in another thread)
Old Oct 22, 2012 | 09:53 PM
audion77's Avatar
audion77
well crap, no i did not use a torque wrench. did i screw the pooch? can i loosen and then tighten to spec or have i given this gasket the final deathblow?
Old Oct 22, 2012 | 10:28 PM
psquare7575's Avatar
psquare7575
Transmission I'm assuming? Sounds like the gasket is fubar.
Also
"Heavy Red Flow
Thought I should start a new thread for an unrelated issue with some leakage I seem to be having."
Sorry, this was the funniest thing I've read on here in awhile.
Old Oct 22, 2012 | 10:31 PM
devino246's Avatar
devino246
Originally Posted by psquare7575
Also
"Heavy Red Flow
I couldn't help but think the same thing
Old Oct 22, 2012 | 10:33 PM
HIO Silver's Avatar
HIO Silver
3x.... I thought yer girl was riding the cotton pony!
Old Oct 22, 2012 | 10:45 PM
joerickson's Avatar
joerickson
Get a new gasket and make sure none of the bolts are stripped. You shouldnt really need a torque wrench for this, just dont tighten them like a gorilla.
Old Oct 23, 2012 | 09:15 AM
jstans's Avatar
jstans
I'd also suggest that you look at the pan and remove any dimples around the bolt holes that may have been caused by over tightening in the past. I use an inverted socket of the appropriate size and lightly tap the metal around the bolt holes. I was taught that by an old Ford mechanic (who just happened to be my father).
Old Nov 1, 2012 | 01:59 PM
audion77's Avatar
audion77
good tip on banging out those dimples. got the new gasket and filter kit in. no more leak!
Old Nov 1, 2012 | 04:55 PM
jeff14346's Avatar
jeff14346
its that time of the month for the trans!!
77f100guy
Jun 30, 2010 03:46 PM
bvieages
Oct 12, 2007 07:55 AM
Scooter77
Oct 11, 2007 12:23 PM
dolcevita09
Apr 6, 2006 10:20 AM
blue02gt
Aug 7, 2005 12:57 PM
