Sponsored by: Real Truck
Poor Acceleration, Low Cold Idle, No Codes...yet
Old Oct 22, 2012 | 01:18 PM
ahoypollloi's Avatar
ahoypollloi
Don't laugh, because I know that there are all sorts of problems it could be with a 1999 F-250 SD, 5.4 V-8 with 261,000 mile on the original motor, but here are the symptoms and my corrective actions:
Symptoms:
1. P0171/P0174 & P0403 Codes (especially after refueling ??)
2. Random misfire (previiously occurring - before DTCs)
3. Rough idle (occurred with codes) smoothed out after PCV replacement
4. LOUSY acceleration (most noticeable after replacing PCV/cleaning MAF)
5. After replacing PCV and cleaning MAF - low idle when cold (at or <500
rpm.
Corrections:
1. Found that freakin' elbow from PCV behind manifold...with a hole big
enough to put my finger in, replaced elbow and PCV valve (old valve
seemed to be fine, but I figured I'd replace it anyway (mistake?)
2. Cleaned MAF sensor on K&N intake and another sensor (resistor?)
downstream of the MAF.
After replacing the PCV, I reset the codes, and don't have any new ones yet..with emphasis on the yet. Could a bad EGR valve cause low idle, or IAC/IAT, or even a vacuum leak? I don't believe that any of the vacuum lines have ever been replaced, and although I maintain it well (look at the mileage!), I neglected replacing things that weren't broken. Any ideas would be appreciated.
lv2race
Jul 16, 2012 02:55 AM
copracr
1983 - 2012 Ranger & B-Series
Jun 10, 2012 02:12 AM
JaxJim
1997 - 2003 F150
Apr 30, 2011 07:41 PM
Jason01
Modular V8 (4.6L, 5.4L)
Apr 17, 2008 12:48 AM
Viper2
Mar 24, 2005 10:10 AM
