4wd swap
Old Oct 22, 2012 | 07:57 AM
pwstroker69's Avatar
pwstroker69
4wd swap
I asked last week about the effort involved in swapping out engine, tranny, drivetrain between gasser and psd. I got good answers and have been looking hard again for a good donor psd. I may have exactly the truck I need, it is already *without* engine and tranny . My new question is this; If I am putting my late 99 psd (2wd) and tranny into an 03 donor, will the tranny blt right to the transfer case from one year to another and from 2 to 4wd?
Thanks as always, this forum is the best.
Old Oct 22, 2012 | 09:22 AM
Kdr358's Avatar
Kdr358
The transmissions are different, the 2wd has the splines on the output shaft to directly accept the drivehaft. The 4wd I believe goes directly into the transfer case. Everything else should be as simple as plug and play after that.
Old Oct 22, 2012 | 12:19 PM
pwstroker69
Great, thanks. But both 4r100 right? So if I change out do you know if the output shaft can be changed?? or is there something else not too complicated that can be done?
Thanks much.
Old Oct 22, 2012 | 01:30 PM
Kdr358's Avatar
Kdr358
If you want to tear down the entire transmission to change it. So your going from your truck being 2wd to a 4x4 donor truck correct?
Old Oct 22, 2012 | 02:52 PM
pwstroker69
Yes, that is the idea.... I was really hoping not to have to do that though. So are you saying the whole drivetrain will be different, from the engine back? IOW, to keep it (relatively) simple, I need a 4wd donor with good tranny and drivetrain. Only do a motor swap?
Thanks,
olbessy92
Apr 10, 2013 08:55 AM
f350ranchand
Dec 7, 2012 01:10 PM
Samell
1983 - 2012 Ranger & B-Series
Sep 20, 2007 06:13 PM
super 6.8
Apr 2, 2007 10:45 PM
ralf
Feb 26, 2007 08:30 PM
