Sponsored by: Real Truck
Error code question....
Old May 19, 2003 | 08:56 PM
RedTaurus94's Avatar
RedTaurus94
My tuner/reader tells me that I have a
P0603 Internal Ctrl Mod KAM Error.
Can anyone tell me in plain English what that is and what I need to do about it?
THANKS in advance.........
Old May 19, 2003 | 09:42 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I think that is the code that is left when you disconnect the batteries.
EDIT: Checked the CD, batteries or PCM have been disconnected.
Old May 19, 2003 | 11:56 PM
Racerguy's Avatar
Racerguy
Do you have a chip?
Old May 20, 2003 | 07:44 AM
RedTaurus94
Yes. I have that Superchip tuner deal. It was already installed when I got the truck. About a week ago, I had changed the program back to stock to compare the performance and fuel mileage. Right before I changed it back to stock, there were no error codes. I found the code when I was about to change it back to the performance mode yesterday. So if I understand the explanation correctly, I just need to clear it out, and it should be OK, right?
I appreciate all you guy's help. It's good to have a place to ask questions and get reliable answers.........
Old May 20, 2003 | 11:17 AM
cookie88's Avatar
cookie88
FTE Emeritus
If you want to, a 603 won't hurt anything if you leave it.
Old May 20, 2003 | 01:47 PM
RedTaurus94
I haven't seen the "Check Engine" light or anything. Just want to make sure I won't have a bigger problem down the road if I ignore it now.........
