Fuel Filter sensor connection?
Old Oct 20, 2012 | 07:38 PM
deaninkc's Avatar
deaninkc
When I was replacing the return lines on my E350 I noticed there was a wire with two connectors that was not connected to anything. There is a green wire with a round connector that seems to fit into sensor on the fuel filter/water separator unit but I'm not sure. There is also a black wire with something that looks like a small rectangular connector that looks like it might be broken off. They both merge into the loom at the same point. Can anyone what these are?
Old Oct 23, 2012 | 07:51 PM
BIGMAC91's Avatar
BIGMAC91
On my 91 7.3 idi there is a small oval type plug that connects directly to the top of the fuel filter housing. I took the top if the filter housing apart because I had a small leak coming out of the hole where the small plug connects. I found that the two terminals run to a round pice of metal that covers the top of the filter, this piece is used as a fuel heater, and makes no change whether it's working or not. Hope the helps you.
-Taylor
tbird250
Nov 21, 2012 12:33 PM
bduemig
13
Aug 16, 2010 03:17 PM
roanie
Oct 5, 2007 06:36 PM
cowboy51
Jan 4, 2007 08:45 PM
fastg60
Sep 27, 2004 08:20 PM
