compression done today
Old Oct 20, 2012 | 05:19 PM
nightowl10's Avatar
nightowl10
Hi all,
Had a compression test done today, and here are some numbers.
Have a 1988 Ford Ranger pickup, 2.0 litre , 4 cylinder engine, 5 speed maual
All 3 cylinders were 140 psi, and one was 110 psi. So I would suspect that rings in this 1 cylinder is gone. Why would not all 4 cylinders wear the same? The truck now has about 130k on speedometer, which is about only about 82 thousand miles. Its weird
Thanks
Old Oct 20, 2012 | 06:44 PM
19704X4F250's Avatar
19704X4F250
Most mechanics want compression readings to be within 15 pounds of each cylinder. Cylinder #1 is on the low side but no they are not gone.
Old Oct 20, 2012 | 07:02 PM
merace19's Avatar
merace19
You have a lot of factors on why the rings dont wear even. Metal in block is not all that great, so can and will have harder spots and thicker spots, Same for rings. Also the way the fuel system feeds each cylinder. One could be working harder than other.
Then we get into valves and if there is crud on back side of them. how much has the cam worn and lifting that valve.... Engines are complicated.
Old Oct 20, 2012 | 09:26 PM
wtroger's Avatar
wtroger
I wouldn't trust one test. Removing the plugs can cause some carbon to be dislodged and get under the valves Squirt a little oil in all cylinders and see what the numbers are If number one comes up to match the others then yes the rings are a bit bad. If it doesn't come up it is a valve issue.
Old Oct 21, 2012 | 06:12 PM
nightowl10's Avatar
nightowl10
Thanks for all the great advice! Have to make a correction here. Starting at the front of the engine is no 1 - 140psi, 2=140psi, 3-110psi, and 4 - 130psi
TruckerATK
Oct 4, 2016 04:31 PM
Ethan1997
Aug 10, 2016 09:58 PM
geodiggr
Dec 2, 2009 05:40 PM
On_Final
May 21, 2008 01:25 PM
88bronk
18
Apr 7, 2004 08:18 PM
