96 F150 no crank
96 F150 no crank
Ive searched all over and havent found much yet so heres my issue.
Randomly shut the truck off one day, and now it doesnt crank. It has a new battery, starter, and starter relay. If you jump the relay it starts up everytime. All cable cable ends seem to be ok. Is the ignition switch the problem? If so what is the best way to test it.
Sounds like you get to become a better friend with your multimeter. As subford already said, neutral safety, then check to see if you have voltage at your key, then coming out. Just start tracing with the meter till you find whats bad. This an auto or a manual?
-Mike
EDIT: So your neutral switch will be your clutch pedal assembly with a manual.
-Mike
