rebuild or replace???
Old May 19, 2003 | 05:42 PM
bruno76's Avatar
bruno76
Question rebuild or replace???
ok i have a couple questions first the story......
alright about 4 months ago the EFI I6 in my 1990 f150 4x4 blew.
the radiator got packed with mud and they kept driving it on the highway till it over heated and blew a hole in the radiator (and i believe blew the motor as well )then towed it home.(there was not oil on the ground or anything so thats y im a little confused about what happend to the motor.
the next day i went to start it and the starter just strained. towed it to my uncles and he pulled apart said water and mud were in the cylenders it was locked up and pretty much need a new motor.
so now i have a little money and want to get her goin again.
option 1:
should i have them rebuild the motor and add cam, headers, MSD etc. that i want to add
option 2perfered option at this point)
should i trade in the core for a remanufactured for about $600 have it installed and the cam headers and ignition switched on the new?
i would be greatfull for any and all input on this topic, i am only 17 so i do realize there is stuff here im probably not considering. and some ideas on prices too.
P.S. i will probably install the headers and MSD myself but my need help with the cam.
thanks,
Bruno
Old May 19, 2003 | 06:01 PM
steve83's Avatar
steve83
Check with your local Jasper dealer - you might find their price on a long block AND the installation is too good to pass up. My brother-in-law's '93 5.8L recently died, and they put a reman in for $3000 in ONE DAY with a 3-year/100,000mi warranty on parts AND labor.
Otherwise, I'd go with a long block with a decent warranty from a reputable national parts store and swap everything over.
Old May 19, 2003 | 07:53 PM
Silver Streak's Avatar
Silver Streak
If the engine was that hot I'd opt for installing a different engine. Even going that route you might be out a core charge if any of your castings are cracked. The heads on these are known for cracking.
What probably happened was the engine got so hot it siezed up. Then coolant ran in from either a cracked casting or a blown head gasket.
Old May 19, 2003 | 09:16 PM
bruno76's Avatar
bruno76
the coolent definatly leaked from the bottom right of the radiator
they said it wouldnt open up had serious power loss and then a load pop and white smoke everywhere i couldnt find anything leaking from anywhere on the actual motor just the fluid from the rad.
