High angle driveline. And a dana 60 kp front. Help
10-24-2012, 08:24 PM
I've had them 65 inches.
If I recall stock reg cab long box is about that.
10-24-2012, 09:25 PM
^I bet you have, you dirty-
err, wrong forum :flip
10-25-2012, 04:05 PM
in the large trucks driveshaft length is usually limited to 5 foot or so. any longer and a carrier bearing is installed.
the kenworth W900 lowboy in work has three 4 foot driveshafts with 2 carrier bearings between the trans and front rear.
10-25-2012, 04:34 PM
I guess your just a over achiever Tom having 3 shafts at once....
10-25-2012, 04:44 PM
10-25-2012, 05:07 PM
im perfectly fine with only having 2.
10-26-2012, 10:43 PM
on
Divorce mounted tcase, problem solved.
10-26-2012, 11:44 PM
Quote:
Originally Posted by
77mud
at the race yesterday i took a look at my speedo it was upwards or 50.... so i dont really consider 10-20 that fast....
This mabey a dumb question but if your wheel speed is around 50, do you put it in 4 high or 4 low on the track? Im guessing 4 high?
10-27-2012, 02:47 AM
Most run 4low.
Ive seen 60-70mph with my hunk of junk
10-27-2012, 10:26 AM
it was in 4lo, but i had just left the line.... and the speedo works when it wants to so not even sure how close it is...
10-27-2012, 11:48 AM
Damn, whats the fastest you can go in 4 low and 4 high? And do yall have a stick shift or auto?
10-27-2012, 11:55 AM
Mines a auto C6... and i think in 4lo at 6000 RPM im turning around 68mph 3rd gear
10-27-2012, 12:27 PM
i can only hit around 45 mph in 4 low.
but then again, my deezles redline at 3000 rpm.
10-27-2012, 01:03 PM
yea mine redlines where ever i want it to.... lol
10-27-2012, 06:16 PM
Ok, so 4 low is good for the track. When should I ever use 4 high? when i need to go faster than 70?
