boost issues
Old Oct 15, 2012 | 03:23 PM
DTS Tech's Avatar
DTS Tech
boost issues
I am currently working on a 2009 6.7. The truck came in with low power. I hooked up my computer and got two active codes P040D (exhaust gas recirculation temperatur sensor A circuit high) & P0528 (fan speed sensor circuit no signal) then I ran a key on engine running self test and got code P2263 (tc/sc boost system performance) I have checked the exhaust pressure sensor and tube to make sure they weren't pluged. The truck is slow to build up boost but the problem seems to be irratic. Does anyone have any ideas or know how to tell if the dpf system is stopped up?
Old Oct 15, 2012 | 03:28 PM
rob92761's Avatar
rob92761
i had a simlar problem with 6.0. it end up being the exhuast persure senor had to put new on and install it to make every thing work right.
Old Oct 15, 2012 | 06:52 PM
kper05's Avatar
kper05
If this is a stock Ford truck, the 2009 is a 6.4L instead of a 6.7L.
Might want to ask the 6.4L folks.
In the 2011+ 6.7L you should be able to get the soot GPL of the DPF.
An active regen begins at 2.66 GPL so any number way above that would be a concern.
I don't know what Ford considers plugged but I would guess over 5 would be bad.
Not sure if the 2009 6.4L has such as computer option but it must know when to active regen.
Old Oct 15, 2012 | 07:29 PM
senix's Avatar
senix
I'd start with a new EGR valve. The turbo uses the egr valve as its waste gate. When you pull the valve the housing will break so get both.
Matt306
Sep 8, 2015 10:35 AM
Jeffrobeans
Nov 17, 2014 04:19 PM
wingrider75
Feb 22, 2014 10:41 PM
phatboy7
Jan 28, 2014 10:33 PM
Carolina Rig
Apr 2, 2012 12:52 PM
