c6 swap questions
Old Oct 15, 2012 | 03:14 AM
JHAM's Avatar
JHAM
c6 swap questions
I have a 96 F150 4x4 that orginally had a 5 spd in it, lost first and second gear in it so then put in a c6. Long story short I burnt it up and now am about to rebuild it. While it is out for the rebuild I am going to put a wide ratio gear set in it because I'm still running the orginal 3.55s with 33s, so the lower first and second gears will help me out until I can change rear end gears.
When I first installed the transmission I was in a hurry, just ran rubber hoses to an aftermarket cooler, I need to fix that. Would the lines from a e4od or another transmission work? I also need a dipstick tube, I used a lokar flexible tube but its not quite long enough to do what I need to do, and the adapter thing to fill it keeps getting lost, frustrating... anyhow I can find c-6 tubes for older trucks, does anyone know if they would fit in my truck? or would a tube from another transmission work?
Old Oct 15, 2012 | 04:18 AM
garthneddy's Avatar
garthneddy
Just get some line and bend them yourself. That way it will fit perfectly and will be much cheaper then purchasing any pre-bent lines.
Old Oct 15, 2012 | 07:54 AM
JHAM's Avatar
JHAM
ok running new lines makes sense, any ideas on the dipstick tube? hoping someone has done this swap before me and will know what will fit
POPAJON
Jan 17, 2019 02:38 PM
Ford Tempo Fan
Jul 30, 2015 06:33 PM
HardFordCore
Mar 11, 2006 07:06 PM
bivens1172
Jun 25, 2005 01:16 PM
