hvac selector issues
Old Oct 14, 2012 | 10:49 PM
dakota1820's Avatar
dakota1820
so my 93 f150 will only blow on defrost. i can grab the little arm under the dash and can make it go to defrost or vents. if i turn the selector **** to ac the ac will come on but i have to manually move the arm under the dash to either defrost or vent. that's the only 2 selections i can use. i cant find any vacuum leaks or any obvious issues. but i really dont understand the system fully either.
Old Oct 15, 2012 | 09:05 AM
subford's Avatar
subford
You either have a vacuum leak or the vacuum line for the system is no longer connected to the intake.
Most of the time this problem is from something under the hood and most of the time it is the white hose for the outside air motor as in the photo below.
Old Oct 15, 2012 | 10:06 AM
dakota1820's Avatar
dakota1820
The picture won't load I will check everything again. It stopped wiring after I changed my plugs
Old Oct 15, 2012 | 11:46 AM
Bigblue351's Avatar
Bigblue351
exacty same thing happend to me when i did my tune up.
$20 bucks says your ratchet caught on an old brittle vaccum house. and either cracked or broke it in half.
check all the lines around where you were working. Fix the Vaccum leak and your HVAC will work properly again!
rvarc
1978 - 1996 Big Bronco
Aug 3, 2018 09:17 PM
1999-F150
1997 - 2003 F150
Jul 10, 2017 08:42 PM
oldcoupe42
Aug 14, 2016 07:39 AM
Mr Dave73
1997 - 2003 F150
Nov 27, 2010 01:41 PM
landjr
Jul 11, 2005 08:56 PM
