Sponsored by: Real Truck
Exhaust studs broken inside head
Old Oct 16, 2012 | 04:31 PM
  #46
1975StroppeBaja's Avatar
1975StroppeBaja
Originally Posted by SuperDutyScaler
huh my 350 dont have that i wonder why? At least you got the studs out and youll be real happy with the headers. Now if Gibson only made long tubes and y-pipe to go with it!
My '04 F250 didn't have it either. Must be something they deleted by '04...?
Old Oct 16, 2012 | 04:34 PM
  #47
acf6's Avatar
acf6
Idk but consider yourself lucky cause it was a 30mm nut and it was ON there. Also made it hard to put header on because there is no play in the pipe
Old Oct 16, 2012 | 07:44 PM
  #48
Hotpocket's Avatar
Hotpocket
my 04 does not have it either and mine was built in late 03
Old Oct 16, 2012 | 08:54 PM
  #49
acf6's Avatar
acf6
pic of the ugly old manifolds!
Old Oct 25, 2012 | 12:37 PM
  #50
acf6's Avatar
acf6
Still trying to figure out what the tick is from, all my spark plugs are tight, the grade 8 bolts i put in for the downpipe connections are still tight and all the header bolts are tight. Guess its just a tick from the headers? Wish someone with a 5.4 with headers lived around here so they could go for a ride
Old Oct 25, 2012 | 08:20 PM
  #51
Bigpipes 35's Avatar
Bigpipes 35
Hey guys I have some broken studs as well and I am not a welder but have access to one. Do I need a mig welder with gas or will a wire feed with flux core wire work ?
Old Oct 25, 2012 | 08:36 PM
  #52
nitrogen's Avatar
nitrogen
it can be done either way I suppose, but in my opinion a stick actually might work better.
Old Oct 25, 2012 | 08:39 PM
  #53
Hotpocket's Avatar
Hotpocket
+2 on the stick..burns the nut on better
  #54
acf6's Avatar
acf6
not sure.. but my friend said he was glad he had a mig to do it with, a stick he said is possible but you need to be extremely accurate with it
Old Oct 25, 2012 | 08:44 PM
  #55
Bigpipes 35
And I am safe on the alluminum head as long as I dont use alluminum flux core wire correct ?
  #56
acf6's Avatar
acf6
yes .
Old Oct 25, 2012 | 09:23 PM
  #57
Quad Racer's Avatar
Quad Racer
A stick welder is alot harder for an inexperienced welder. I'd go with a mig = easier. The heat from the welding alone does alot of the work IMO. Disclaimer= I have never completed this repair so take it for what it's worth..
Old Oct 26, 2012 | 06:41 AM
  #58
meborder's Avatar
meborder
if you are going to use a stick welder, use an auto-dark helmet.
while i haven't done THIS repair, I've spend a fair share of time behind a welding mask. you'll never hit your target without a helmet you can see through.
i'd use a wire feed of some kind.
Old Oct 26, 2012 | 06:51 AM
  #59
Bigpipes 35
I am going to use a wire feed its just not a mig.
Old Nov 27, 2012 | 10:04 PM
  #60
klimek460's Avatar
klimek460
i found it seams to help if you rattel the welded nut softly with a air hammer after welding them then slowly work them back and forth. this is an all day project from start to finsh unless your lucky. it also helps to walk away for a bit if your having trouble they tend to come out better after you take a brake.
