Truck wont even turn over now. Tried disconnecting wire to egr, threw codes p0403, p0405, p0299. Then, reconnected egr and it started up, but still not running right. My edge says mod volt is 11.0. Fuel presure gage says 59 psi, which is what it normally runs at. Any ideas? Could it be the batteries?
Whats Mod Volt???
FICM Module Voltage??? Just a Guess
But Honestly any Voltage at 11.0v is Bad Unless that was taken During starter Engaugement
It would be a Good Idea to check alternator output and Load Test Batterys Separatly
Even a Battery Specific Gravity Hydro test is a Good Indicator there 5 buck from parts store
last week I found a Bad Battery with Hydro tester and FWIW the Battery Volts test Showed good so thats a Good thing to have for a DIYer
Running an engine with ICP unplugged puts the PCM strategy into FMEM mode, meaning it will "estimate" the actual amount of ICP present, based upon APP, MAF, MAP as well as various other sensors' input. If the actual ICP is far less than what is "estimated", the engine will run and drive horribly.
First off...a huge thanks to all who posted!!!!!i owe u guys bigtime. I was able to make it home..i drove at about 70 for 2 hours with the icp unplugged. The truck may have been a bit more sluggish, but it wasnt that bad. I kept an eye on oil temp, coolant temp, fuel press, boost...no noticable change. Thanks for the part numbers! I just saw a video on youtube of a tech saying no code or p0299 with no start, hesitation, surging to check icp. Thanks again guys!!!!!!!!!!!!!!!!
