No Spark
Old Oct 12, 2012 | 04:56 PM
ray04gt's Avatar
ray04gt
No Spark
Hey guys I just recently put the motor back in my 1979 F250. It is the 6.6l 400m motor. I can't get any spark. I'm not sure but I'm pretty sure the ignition control module is hard wired. Please lend me a hand
Old Oct 12, 2012 | 05:22 PM
fmc400's Avatar
fmc400
MSEE
Welcome to FTE. First step: connect a test light from the TACH TEST (negative) terminal of the coil to clean, unpainted metal on the engine (ground). Crank the engine over from the key, and the light should BLINK. Post your results.
Old Oct 12, 2012 | 05:28 PM
ray04gt's Avatar
ray04gt
Thank you for the warm welcome. Se the thing is... I have no idea if I have it wired up right or not. I didn't remove the motor from the truck I just got the job of putting back in. I need like I wiring diagram for an ignition module that's hard wired
Old Oct 12, 2012 | 05:29 PM
fmc400's Avatar
fmc400
MSEE
Can you describe what you mean by the ignition module being hard wired?
Old Oct 12, 2012 | 05:37 PM
ray04gt's Avatar
ray04gt
There is no big ignition module under the hood on the drivers side it's just a small box with wires coming from the ignition switch and the ignition relay. It has a jumper wire on it as well
Old Oct 12, 2012 | 05:50 PM
fmc400's Avatar
fmc400
MSEE
I guess I'm not quite following. The ignition module is essentially a box with wires coming out. There is no relay in the original ignition system. Instead of trying to understand what's there, focus on how it should be, and what you must do to make what's there match what should be there.
Here is a diagram of the original Duraspark system:
Old Oct 15, 2012 | 04:41 PM
ray04gt's Avatar
ray04gt
Ok so I had to get a new coil. Now I have 3 wires that come from the distributor purple orange and black. The have no where to go...? I know they should plug into the ignition control module but it's not there. It never was. So now I'm really lost
Old Oct 15, 2012 | 05:16 PM
fmc400's Avatar
fmc400
MSEE
All three of those wires go straight to the ignition module. It mounts to the driver side inner fenderwell toward the firewall. If your '79 is missing it, you'll need to get a new one.
The factory electronic ignition cannot operate without the ignition module (there is nothing to switch the coil if it's gone).
Old Oct 15, 2012 | 05:26 PM
ray04gt's Avatar
ray04gt
That's makes sense but... It never had one before and it ran
Old Oct 15, 2012 | 05:31 PM
fmc400's Avatar
fmc400
MSEE
It is physically impossible for an electronic ignition system that uses the distributor you've mentioned to run without the ignition module. Without the module, there physically is no method to switch the coil primary winding and fire the spark plugs. It's like saying points ignition can run without the points.
If you're saying the engine ran when it was in the old truck, then obviously that truck's ignition module was still bolted to the fender. When the engine was pulled, the engine came out but the module stayed in the truck. It does not typically travel with the engine.
If you're saying that truck didn't have an ignition module either, then something else was different; either the engine was using points, or a Pertronix conversion (which is an ignition module). But in those two cases, you wouldn't have those three wires coming from the distributor.
Or, that truck really did have an ignition module and you just didn't see it.
Old Oct 15, 2012 | 05:39 PM
ray04gt's Avatar
ray04gt
ok i figured it out i went threw some picks. The motor that was in the truck i have before whick ran had a 2 wire msd distributor not an OEM 3 wire. now what do i do? run a 2 wire msd typ distributor?
Old Oct 15, 2012 | 05:45 PM
jstans's Avatar
jstans
Or you could get the original style ignition module Standard Motor Products LX203 - Standard Motor Ignition Modules - Application - SummitRacing.com
Old Oct 15, 2012 | 05:50 PM
ray04gt's Avatar
ray04gt
Yeah but to do that id need a wiring harness because whoever had the truck before me left no wires in it
Old Oct 15, 2012 | 05:51 PM
jstans's Avatar
jstans
It's also available on LMC's site Truck Parts and Truck Accessories
Old Oct 15, 2012 | 05:54 PM
fmc400's Avatar
fmc400
MSEE
Do whatever is cheapest. If you already have a Duraspark distributor, then it will most certainly be cheapest to get a Duraspark ignition module (this is all the factory stuff) and then hook it up. I already provided the wiring diagram for this.
Either way you will not get around the fact that you will have to add the wiring in between whatever you end up using yourself. If it's missing, you must replace it. There is no 5-minute solution for an engine swap with cut up wiring and missing pieces.
