Member stranded (Blue Mule )
Old Oct 12, 2012 | 11:55 AM
Action4478's Avatar
Action4478
Both of the replacement pumps run , the old one does not . He is using a fuel supply from a jug hooked directly to the pump , Fuel siphons into the new pump ,but nothing comes out , Its definitely the pump..
Old Oct 12, 2012 | 11:57 AM
DIYMechanic's Avatar
DIYMechanic
Sure he has the pump hooked up right? It's hard to imagine he got two bad pumps back to back.
Joseph's sig says he is in Vanderburg County.
Old Oct 12, 2012 | 11:59 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Red face
I only can see his possible location by Google Earth, and in the border line between Illinois and Indiana on the I70 I can see a truck stop place there, and I could see that is between Marshall and Terre Haute.
Good luck.
Old Oct 12, 2012 | 12:01 PM
DIYMechanic
Yeah looks like Joseph is probably about 2 hours away from him.
Old Oct 12, 2012 | 12:03 PM
Action4478's Avatar
Action4478
Originally Posted by DIYMechanic
Sure he has the pump hooked up right? It's hard to imagine he got tow bad pumps back to back.
Auto zone pumps .. Rodney did the conversion himself years ago , he knows what he is doing , for sure ..
both pumps run & he tried switching them around since the inlet & outlet are not labled ..
Old Oct 12, 2012 | 12:13 PM
DIYMechanic
I don't doubt he knows what he is doing. I was thinking more along the lines that the electrical could be hooked up backwards and the pump was spinning backwards or something. I have seen that before with electric fuel pumps where the connections aren't labeled for the electrical and share the same type of wire connector.
I wish I could be more help.
Old Oct 12, 2012 | 12:22 PM
Action4478's Avatar
Action4478
I'll pass that on ..Thanks .
You may be on to something but I get his voice mail & haven't heard back ..
Old Oct 12, 2012 | 12:39 PM
Action4478's Avatar
Action4478
He was running a super duty pump set up , not sure if the AZ pump hooks up the same electrically ...
Old Oct 12, 2012 | 12:52 PM
DIYMechanic
Yeah I don't know either, but if the pump is running backwards, you can't just switch the hoses around and have it work. The pumps are only going to pump fuel when they are running the right direction.
That's it for my arm-chair quarterback routine here. He is the one under the truck. I am just speculating. Hopefully he has what he needs to get the job done.
Old Oct 12, 2012 | 12:54 PM
BIGRED 7.3L's Avatar
BIGRED 7.3L
Scheid Diesel is right there, an exit further into Indiana at the Terre Haute exit. They might be able to help.
Terre Haute, IN 800-669-1593
Old Oct 12, 2012 | 12:55 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Searching in the web I found this:
The strainer that came on the pump from autozone had disintegrated and fallen off and there was a large piece in there. I found another one actually I must have missed when I first replaced it from an older pump, more of a thick canvas looking material. between the two pieces of debris in there they'd get sucked up against the intake and I wouldn't get any fuel.
IDK. Just trying to help.
Old Oct 12, 2012 | 01:03 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
I know plenty of Ford guys that will never go back to Scheid, seems they are not too Ford knowledgeable.
Hope Rodney get's it figured out.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Oct 12, 2012 | 01:10 PM
  #28
DRRXR's Avatar
DRRXR
I gave a holler out over here
https://www.ford-trucks.com/forums/1...l#post12366070
Old Oct 12, 2012 | 01:28 PM
  #29
stainlessstroker95's Avatar
stainlessstroker95
I am an hour away i will give him a call
Old Oct 12, 2012 | 01:37 PM
  #30
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Identical.
Was only there once back in 03. I won't contaminate this thread with details, but suffice it to say I agree.
