command start problem with 2008 explorer
Old Oct 11, 2012 | 11:54 AM
llbplumber's Avatar
llbplumber
my command start for 2008 explorer was installed by ford dealer couple of years ago . now when i press remote start, horn beeps 1 time, doors lock, lights come on then it should start but instead horn beeps once again and vehicle doesn,t start , radio and heater in vehicle run as if vehicle was started
Old Oct 11, 2012 | 12:28 PM
shorod's Avatar
shorod
Have you checked the manual for the remote start to see what that second horn honk indicates? Sounds like a diagnostic of some sort. Maybe it's telling you that it senses an open door, or the brake pedal depressed, etc.
-Rod
Old Oct 11, 2012 | 12:39 PM
llbplumber's Avatar
llbplumber
command problem
yes i checked manual and is a little confusing because i don,t know if the first beep counts as1 when command is pressed then when vehicle doesn,t start as second beep. 2 beeps is hood open no place does it mention 1 beep. i tried command start with hood open and sure enough, horn beeps once when command button pressed then beeps twice when vehicle doesn,t start so obviously 1st beep doesn,t count i guess!!!! but then what does i beep mean when it won,t start?
Pool Runner
2009 - 2014 F150
Nov 7, 2013 03:02 PM
tinman565
Oct 17, 2012 05:55 PM
Explorerfan2
Apr 28, 2011 02:15 PM
nelgrenrut06
2004 - 2008 F150
Apr 6, 2011 11:09 PM
