Heater return tube
Old Oct 10, 2012 | 08:45 PM
GLR's Avatar
GLR
Heater return tube
1987 SCab 460 4v. Anybody happen to know the part number for the heater return tube that screws into the water pump? Is there an "O" ring used for a seal? Had to heat mine up to get it loose, so if it had an o ring it's toast. Local Ford garage didn't know, and I couldn't find any info in my shop manual. Thanks.
Old Oct 11, 2012 | 08:16 PM
GLR's Avatar
GLR
After more running around, I was able to remove the return tube from 85 parts truck (fits 83-93 460 according to dealer). Dissecting it, grind off the "stakes" at the bottom of the threaded end, the nut will slide off. There are 2 "o" rings that go between the tube and the nut to seal it. Local NAPA didn't have any that would work, so have to do some more checking tomorrow.
Old Oct 12, 2012 | 03:22 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
When I installed a rebuilt engine in '08 I had to replace the tube.
Not because it had rotted, but because of the seal on that gland nut.
IIRC, it was ~$100 from the dealer.
Old Oct 12, 2012 | 07:48 AM
GLR's Avatar
GLR
As my above post, I'm learning how to fix it. Now if I can find the right "O" rings.............
Local Ford parts guy is off to "deer camp" so I might have to wait until next week.
Old Oct 13, 2012 | 10:18 AM
RockWVU's Avatar
RockWVU
Why can't you just use a regular nipple type fitting and heater hose?
Is the smog braket in the way?
Old Oct 13, 2012 | 10:27 AM
GLR's Avatar
GLR
Hi Rock, yes the smog bracket is in the way. Found some o rings, used waterproof grease for lubricant, staked the end where the gland nut goes on, got it installed. Have to finish some of the work, then pressure test the system for leaks. Waiting for it to warm up.
Old Oct 13, 2012 | 10:38 AM
RockWVU's Avatar
RockWVU
I destroyed that line when i took my motor apart on my 86.
I also removed my smog pumps and cut the alt/smog braket down.
I am thinkg/hoping that i can use a regular fitting now since i cut most of the bulky braket off except waht i need to mount the alternator.
I just got the motor in the truck yesterday and have to work on the accessories.
Old Oct 13, 2012 | 10:45 AM
GLR's Avatar
GLR
On my 86 with the 351, the smog brackets "fell off". Mounted the alternator with just the long bolt and the adjusting bracket. Been ok for about 6 years now.
Old Oct 13, 2012 | 10:50 AM
RockWVU's Avatar
RockWVU
double post
z 97ford1
Jul 14, 2014 10:22 PM
PSDVirgil
Modular V10 (6.8l)
Nov 5, 2013 03:13 PM
tapnibot
1978 - 1996 Big Bronco
Jan 10, 2006 07:40 PM
51f1
May 8, 2003 06:22 AM
