Temperature change
Old Oct 10, 2012 | 06:33 PM
midsouth's Avatar
midsouth
Temperature change
On my 83 f150 4x4 5.8 liter the faster i travel, the hotter the engine gets. The truck doesn't over heat, just runs hotter. Of course Fords run hot. Would an an antifreeze change help keep the temperature normal? I've learned that the repair shops that utilize the forced flush tend to do more damage than good. The thermostat, senders, and sensors are new and are working as they should. In addition to the many questions, do the repair shops simply empty the radiator? Any advice would be great.
Old Oct 10, 2012 | 06:53 PM
kermmydog's Avatar
kermmydog
Do you have a fan clutch? If so it may not be working correctly.
Craig
Old Oct 10, 2012 | 07:12 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Craig
Shouldn't be an issue if he says "the faster I travel the hotter it gets"
At highway speeds the fan is contributing very little to flow over the radiator.
The radiator may have scale or clogged tubes inside.
There may be mud or bugs packed in the fins.
Maybe the water pump impeller has rusted away.
Who knows?
But I would check for flow with the thermostat hot and open, and do some investigating as to why the radiator can't shed enough heat.
Old Oct 10, 2012 | 07:58 PM
mmalte2's Avatar
mmalte2
Is the radiator the correct size? Air in the system?
Old Oct 10, 2012 | 09:01 PM
1983F1503004x4's Avatar
1983F1503004x4
Fords don't run any hotter than any other vehicle if they're taken care of. You should see temperatures around 190* when cruising, and nothing over 200.
The stock thermostat is around 192 degrees.
Do a back flush on the cooling system until the antifreeze/water comes out clear. Change all your cooling system hoses, and refill with 50/50 premix antifreeze.
Do NOT use well water to flush your radiator. You're truck is probably heating up so much because of rust/corrosion in the cooling system, and putting rust in there won't solve the issue.
EDIT:
Just thought of something else as well. Make sure your radiator isn't packed full of crud, and make sure it isn't damaged in any way.
Old Oct 11, 2012 | 02:35 PM
Skoiv's Avatar
Skoiv
I know it is obvious and you probably already did but....check the oil level too. Mine got hot on a long trip and it was all due to a low oil level.
Old Oct 11, 2012 | 03:02 PM
Franklin2's Avatar
Franklin2
Who knows?
I agree, you need to take the cap off the radiator and look down inside. If you see a lot of white stuff, you need a new radiator.
knecoli22
Jun 23, 2010 10:46 PM
Sharpshooter77
Sep 10, 2007 08:47 PM
Ken86F350
May 19, 2006 06:57 PM
tlb
Aug 7, 2005 01:48 PM
rje053103
Jul 16, 2003 07:17 PM
