MSD Complete set up?
Old Oct 10, 2012 | 12:16 AM
SuperDuty93's Avatar
SuperDuty93
Ok been needing to replace the old distributer (no points) and get something a little more powerful and everyone keeps saying MSD. So thats where im looking right now.
So to make a long story short, whats the best set up for a 390 with mild racing cam? Idk if the cam makes a difference or not but i need a nice performance dist.
MSD Ignition
Old Oct 10, 2012 | 02:57 AM
410F-100's Avatar
410F-100
i just ditched my msd for a dui. and noticed quite a big difference over the msd!
was msd 8595, 6al, blaster 2, and msd superconducter wires.
now dui stand alone dizzy, and same wires and plugs. same timing curves, but better low end...
only bad thing w/ the dui (other than being a gm design) its not as clean, ugly compared to msd's design... the clear cap dosent quite make up for the bulky design...
i had problems w/ moister corroding things in the msd, and advance springs binding w/ the weights... keep spair springs w/ truck,maby small pliers to reshape the springs from binding on the weights and allowing the advance to stick open...
took a couple years before my problems started, and my new replacement springs required bending to clear advance weights..
if you go msd and msd box good chance need colder plugs too, but every engine is different
Old Oct 10, 2012 | 10:29 AM
vic_v8's Avatar
vic_v8
MSD quality has gone down greatly over the years, I personally used to use them, but now stay away.
Old Oct 10, 2012 | 10:48 AM
crsweet78's Avatar
crsweet78
It seems like everyone has their preferance when it comes to ignition setups. I have the complete MSD setup and I love it. Ive had it for almost 4 years now after all my stock stuff was failing. Plus living in California it was all smog legal.
Old Oct 10, 2012 | 05:29 PM
SuperDuty93
Do you remember what item/part numbers your set up was?
Old Oct 10, 2012 | 05:34 PM
jeff14346's Avatar
jeff14346
use the DUI HEI set up, one wire switched 12 volt source and done, put one on my 390, runs great!!!!
Old Oct 10, 2012 | 05:59 PM
crsweet78's Avatar
crsweet78
Couldnt tell you the model # on the pro billet distributor, I dont have the 390. But they should make one for the 390 just check summit. Ignition box is the 6A model and then a blaster coil and the plug wires.
Old Oct 10, 2012 | 06:33 PM
SuperDuty93
Mkay so on the MSD web page i can put in my make model and year and block size and it gives me the options for what to get. It seems as if the 74 and 76 390 coils are different and im about to check the 6amp thing to see if they are the same. Found that to be weird, why would a 74 be different then a 76 390?
See if these work...
http://www.msdignition.com/appguidedomestic.aspx
Also is getting a distributer without the vacume advance an option?
Old Oct 16, 2012 | 06:47 PM
SuperDuty93
If i go with MSD, can I use any spark plug wires or do i have to use the MSD ones? Because i was going to use these if possible
Ford Racing M-12259-T462 - Ford Racing Spark Plug Wire Sets - Overview - SummitRacing.com
Old Oct 16, 2012 | 07:10 PM
hickory1991's Avatar
hickory1991
The guy that built my 390 used the pro-billit dizzy, 6al box, blaster coil, and ford racing wires. It only has been broken in and dyno tested so far, but ran great. Medical issues have brought my build to a halt for now.
Old Oct 16, 2012 | 07:54 PM
SuperDuty93
So it is possible i can use whatever then? Because look closely at the part that goes on the cap itself not the plug, it seems to have a clip on the FORD RACING WIRES....?
Old Oct 16, 2012 | 08:04 PM
KIKKUP's Avatar
KIKKUP
Have you considered using a Pertronix conversion to get rid of the points? If your distributor is not worn out, this might be much cheaper and easier to install and delivers good results.
Ignitor II
Old Oct 16, 2012 | 08:07 PM
SuperDuty93
Ignitor II
I dont have points Haha someone already switched it out but yea this thing is still shot, time for a serious upgrade to go with everything else
Old Oct 16, 2012 | 09:58 PM
KIKKUP's Avatar
KIKKUP
Sorry SuperDuty93, I miss-read your post.
Old Oct 17, 2012 | 01:35 PM
etachell's Avatar
etachell
After having vibration troubles with MSD stuff I switched over to the Crane Fireball ignition with their E Core coil. I used a duraspark distributor that I recurred to my engine needs and run Magnecor plug wires. It's a hot ignition and works real well for me. The advance curve made the best overall driving difference.
