Hole in Front Differential
Old Oct 9, 2012 | 01:05 PM
Reptar's Avatar
Reptar
I just bought a used 1997 Ford Ranger, where the previous owner lifted it. I was replacing one off the U-joints when I noticed a hole in the front differential. It looks like it was caused from hitting one of the plates when the wheels flexes. I have no idea what to do about this. Any suggestions? Oh and I attached pictures of what the hole and plates look like. Thanks.
Old Oct 9, 2012 | 05:48 PM
grandmas77f150's Avatar
grandmas77f150
Either replace the entire axle housing or find a certified welder and have it patched.
My opinion: Replace the whole housing
Old Oct 9, 2012 | 07:42 PM
reddog99's Avatar
reddog99
I think I agree with grandmas77f150 on replacement. There's no telling how long that hole has been collecting dirt, or how many chunks of metal are in the diff, and how much it's been driven in that condition. I'd be surprised if the gears and bearings aren't trashed. When you replace the diff you also need to install a suspension travel limiter so that it doesn't happen again.
Old Oct 10, 2012 | 12:25 AM
Reptar's Avatar
Reptar
Yeah, I figured I was going to have to replace that, but I was wondering what I should do to stop it from happening again. If I put bumpstops in there so it wont hit anymore, it looks like it will severely limit the travel, considering there is only a couple inches between the diff and the plate that ripped a hole in it. Any other ideas?
Old Oct 10, 2012 | 01:12 AM
khadma's Avatar
khadma
Carpenter Local 745
Bumps stops yes.
Don't bother welding because you have to remove third member anyway
To clean up the mess!
Those are a dime a dozen from a recycle yard.
Did I mention bump stops?
Old Oct 10, 2012 | 07:04 AM
fordman67's Avatar
fordman67
Or form a large thick metal patch.maybe 3/16 or 1/4. Clean diff and make sure it will live first.then use some body panel bonder to glue it on .it would get you by for a while and the steel would not fracture like cast alluminum.
Replacement is the right way dont get me wrong.a plate on a new one along with limiter is good insurance also...
Old Oct 10, 2012 | 01:55 PM
reddog99's Avatar
reddog99
A bump stop won't limit your travel as much as you think (at the wheel) since the link travels in an arc. Besides, you really don't have any choice...
Old Oct 10, 2012 | 06:43 PM
Phinxter's Avatar
Phinxter
JB Weld! used it to patch my rusty leaky oil pan, has held for 4 months so far haven't leaked a drop. Beats pulling the motor, and cost some time, a grinding disk, brake clean and about $5
Old Oct 10, 2012 | 07:50 PM
grandmas77f150
I hope you're kidding.
Old Oct 11, 2012 | 01:31 PM
reddog99's Avatar
reddog99
JB Weld would probably fix the hole but not the internal damage that's probably been done. Something I hadn't thought of before is that the impact that created the hole may have cracked the diff case, too (visible or not).
Putting that hole there must have been like swinging a sledge hammer on the case.
Old Oct 11, 2012 | 03:27 PM
khadma's Avatar
khadma
Carpenter Local 745
You still have to remove the third member(the damaged piece that has
to be replaced) anyway to get all the rubbish out, let alone look for
any other damage.
Although replacing damaged pieces is best, I did repair a cracked oil
pan on a Contour with JB Weld. You would not think that it would
work, but it did hold up.
Reptar, you could patch it, but donʻt engage the front axle.
Old Oct 11, 2012 | 05:11 PM
Reptar's Avatar
Reptar
Alright. Thank you for all the responses! It sounds like I should just replace it. does anyone know where I'd be able to get one? Would I get it online somewhere?
Old Oct 11, 2012 | 05:45 PM
grandmas77f150
Most junkyards would have an axle
Old Oct 11, 2012 | 05:49 PM
khadma's Avatar
khadma
Carpenter Local 745
I agree........
Old Oct 11, 2012 | 05:52 PM
Phinxter's Avatar
Phinxter
Nope. I bought the truck for $500, the engine had been neglected, it knocks when cold, but runs strong. To change the pan it would be easiest (so I have read) to pull the motor. If I pull the motor it's getting a rebuild and i'm not in love with the truck enough to do that....at least not yet. I was tired of oil spots in my driveway, and that was a cheap and easy fix. Guys all over you tube have done this so it was worth a try, so far so good!
