A/C vents
Old May 18, 2003 | 10:28 PM
optikal illushun's Avatar
optikal illushun
A/C vents
how do i remove the A/C vents on a 1993 f-150 (the part that moves) i need to replace 3 that are broke...
Old May 19, 2003 | 12:03 AM
steve83's Avatar
steve83
A/C vents
Work a small flat-blade screwdriver in beside them. There are 2 snaps on each side. If you pull the cluster bezel, you can look at what you're doing. The 2 on the passenger side are the same.
Old Aug 14, 2007 | 09:10 PM
msgntsu's Avatar
msgntsu
I have the same problem. The middle vent is broken (one with the arm that move the air side to side). I have the horizontal piece (one with arm), but the piece is missing that it attaches to that holds it up. Can this part be replaced?
Old Aug 15, 2007 | 03:26 PM
lostin90s's Avatar
lostin90s
Just a 1 inch puddy knife work in one side pull out easy on adjuster and then other should come out .
Look closely there is small gear set up in they can come out of gear. Any way practice on you broken one before you move to the donor truck to remove later.
