Washer Leak
Old May 18, 2003 | 10:15 PM
AnthonyTek's Avatar
AnthonyTek
Question Washer Leak
This is my first post to this forum, but a lot of great info has been read so far. I have a leak which causes all my washer fluid to leak out somewhere behind the front passenger side wheel well. Initially I found a coupling in the kick panel under the glove box seperated. Slid them back together, and it fixed the leak for the weekend. Today the fluid drained out again. I checked the previous spot, but that is still joined together. Now apparently the leak is somewhere between that coupling in the kick panel, and where the hose feeds into the front fender under the hood. Now my problem is HOW can i access the ~12" of tubing inside the fender??
Thanks in advance
Anthony
2000 4x4 EB
Old May 19, 2003 | 08:57 AM
sailorever's Avatar
sailorever
Cool Washer Leak
Same thing happened to me on my 99 expy. put washer fluid in it and run the rear wiper washer. if nothing comes out of the rear it means the coupling in the wheel well is out. All u do is take out the plastic well cover and u'll see it. Hope this helps.
