HOLY SCORE, BATMAN!!
Old 10-07-2012, 08:10 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Thumbs up HOLY SCORE, BATMAN!!
Old 10-07-2012, 08:18 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
As you can see I picked up a few parts today. Guy was advertising a 223 and 4sp for a hudred bucks on CL. I went to pick it up last week and saw what he's doing. He was looking for a 5.0 and an AOD to put in his '59 F350. Well I had those. So after some thought, we did some horse trading. 2 engines, 2 trannies, starters, a 1904 carb. driveshaft yoke, 2 clutches, a clutch M/C+slave and even a bumper. I think I did pretty well. He's happy too and he did pretty good. He also got a Holley 390 and a stock 5.0 4v manifold outa the deal.
Old 10-08-2012, 11:40 AM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
Did you get a picture of his '59 F350? Best truck Ford ever made...
Old 10-08-2012, 03:27 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Gary I sense a little bias! Oops excuse me I have some sand in my eyes.LOL
Old 10-08-2012, 04:09 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
I take it you know Will? He's a straight up, honest guy. Told me about a '59 @ Pull and Save that had a radiator I need. I got it and the GM 10SI alt with brackets and belt off it. I'll naturally get a new belt, but at least I can take it to my parts guy to match up with a new one.
Old 10-09-2012, 10:23 AM
GB SISSON's Avatar
GB SISSON
No, I don't know him.... Just bragging up my truck, as usual. Those photos of the 223 and it's components will be like 'engine ****' to certain individuals
Old 10-09-2012, 03:21 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
The guy I got these from pull them from an F350. He's going the 5.0 AOD route.
Old 10-21-2012, 03:32 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
It'll now be spring before I install the used engine. I decided to give it a gasket set including head gasket. When I pulled the head, there isn't even any ring ridge. So I'm gonna hot tank it, do rings, bearings timing chain and install the already reworked head. The best of the two transmissions is going in with a new clutch and everything else is being sold for scrap.
Old 02-06-2013, 05:23 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Finally seeing progress.
The engine is ready to install. I'm using an Autolite 1100 carb for three reasons:
1) I have it
2) I know it's good
3) It's non spark control.
Old 02-06-2013, 05:26 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Old 02-07-2013, 05:47 AM
hiball3985's Avatar
hiball3985
hiball3985 is offline
Looking good! What is that distributor??
Old 02-07-2013, 09:24 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Duraspark. I had to open up the stock 223 drive gear and install it because of the different tooth count. But it fits and will work fine.
That's where the Autolite 1100 comes into play as it isn't a 'crapomatic' carb.
Old 02-07-2013, 10:09 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Here's a better look at the dizzy install. I'd prefer it if I could put it in one tooth ahead of where it is, but the base of it then hits the first bolt that holds the lifter cover in place.
IMO it's false economy to put a used oil pump in a fresh engine. So I ordered a new one (Melling M-67A) for a '64. It takes a 5/16" drive shaft rather than a 1/4". So I didn't have to thin down the stock one, just cut about an inch off the new one.
Old 02-07-2013, 09:48 PM
hiball3985's Avatar
hiball3985
Ingenious
Old 02-08-2013, 09:26 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Ingenious
Thanks. I think it looks pretty good. I just scored a stock fuel pump with a glass bowl on the bottom. When it gets here I'll install it. I also have a piece of 1/4" aluminum I'm thinking about using as a mount/heat sink for a GM 4 pin ignition module mounted somewhere in the fuel pump area. Then all the ignition wiring will be in the same neighborhood on the engine. Still have some head scratching to do on that.
Quick Reply: HOLY SCORE, BATMAN!!
