help!
Old May 18, 2003 | 08:46 PM
stevesbigbad4x4's Avatar
stevesbigbad4x4
help!
HI i have an '86 f250 4x4 with a semi floating sterling 10.25. It currently has 4.10 gears. I want to put 5.13's in it but the lowest i can find for a 92 and older 10.25 is 4.56. any body know where i can get 5.13's or possibly even lower? Your help would be appreciated.
Old May 19, 2003 | 01:09 AM
steve83's Avatar
steve83
Old May 19, 2003 | 09:35 AM
stevesbigbad4x4
help!
i have tried all those places, the only place that has close to what i need is randys ring and pinion. They have 5.38's but they only fit a '93 and new axle.
Old Oct 14, 2003 | 03:20 PM
Timl's Avatar
Timl
Steve the reason they only fit 93 and newer is because the yoke splines are longer on the newer axles. You can use the newer gears with a new longer yoke.
Jeffs bronco graveyard has 5.38:1 gears for $199.00
http://broncograveyard.com/products/cat/20/228/31917
