1978 - 1996 Big Bronco
Map Lights Work!
Old May 18, 2003 | 08:42 PM
Sudsrat's Avatar
Sudsrat
Talking Map Lights Work!
Every once in a while I flip the switch on the map lights to see if by some miracle they will go on.They have not worked in about two years.Wouldn't ya know it they both came on today!Don't know if I may have jiggled something while taking the hard top off.I'll see if they continue to work.If not,Where can I trace the wire to?
Thanks
Sudsrat
Old May 18, 2003 | 10:27 PM
Mary_Kate_Olsen's Avatar
Mary_Kate_Olsen
Map Lights Work!
It runs down the driver's side b-piller and under the carpet and doorsill. Also check the ground wire that runs along with it.
Old May 19, 2003 | 12:27 AM
steve83's Avatar
steve83
Map Lights Work!
The wiring usually corrodes into green powder right under the driver's shoulder belt reel.
Old May 19, 2003 | 01:26 AM
greystreak92's Avatar
greystreak92
Map Lights Work!
"green powder" yuck.....copper oxide! Where does the moisture come from Steve? Or is it just condensation over many moons? I only ask in an effort to alleviate the problem prior to it happening to mine.
Old May 19, 2003 | 08:02 AM
steve83's Avatar
steve83
Map Lights Work!
Every time you step in from the rain, the water on your feet runs along the carpet under the threshhold, and down into the channel where the wire runs. Then it wicks or sloshes (as you accelerate) up the wire to that connector, and corrodes it. It's worse if you're a smoker because the ash gets washed down with the water, and ash is caustic.
Old May 19, 2003 | 11:41 PM
greystreak92
Map Lights Work!
Cool, time to figure out a preventive procedure for that likely problem. Thanks.
Old May 20, 2003 | 05:14 AM
Sudsrat's Avatar
Sudsrat
Map Lights Work!
Thanks M.K. & Steve83,
If they fail again, I'll trace the wire,replace where corroded and cover with shrink tube.
Sudsrat
Go Fish!
Old May 20, 2003 | 09:28 PM
Sudsrat's Avatar
Sudsrat
Map Lights Work!
Just noticed that the map lights work only when the dome light is on.I don't remember if this is the way it's supposed to work,or do I have a short in the system?
Sudsrat
Go Fish!
Old May 20, 2003 | 10:00 PM
bigric's Avatar
bigric
Map Lights Work!
You have a problem somewhere. Presumably, you'd have enough light to read a map if the dome light were already on.
Have you tried removing the light assembly and checking to see if anybody has done any "special" repairs to the wiring? I suspect that perhaps somebody attached a wire intended for the dome lamp to power the map lights.
Old May 20, 2003 | 10:09 PM
Sudsrat's Avatar
Sudsrat
Map Lights Work!
bigric,
Looks ok inside and I do remember them working independently
of the dome light.Don't think anyone has screwed with it,but I'll dig deeper.
Sudsrat
Go Fish!
Old May 20, 2003 | 11:03 PM
steve83's Avatar
steve83
Map Lights Work!
The map lights should work ALL the time. I bet your wires have corroded together down there, because the maps & dome are on separate circuits. (Well, they're supposed to be separate! )
Old May 21, 2003 | 05:16 AM
Sudsrat's Avatar
Sudsrat
Map Lights Work!
I'll tear it apart this weekend(if we ever get a nice day here in eastern Pa.)and let you all know what I find.
Sudsrat
Go Fish!
Old May 27, 2003 | 05:16 AM
Sudsrat's Avatar
Sudsrat
Map Lights Work!
WILL IT EVER STOP RAINING HERE IN THE PHILLY AREA?Since I don't have a garage,I need a break in the weather to work on the truck.Hopefully this week I'll get to the wiring.
Sudsrat
Go Fish!
Old Jun 1, 2003 | 04:08 PM
Sudsrat's Avatar
Sudsrat
Map Lights Work!
Ok,it finally stopped raining.Took the belt cover off and pulled back the carpet a bit.What did I find in that well? 3 screws,a nail,a paper clip,an old penny(to corroded to read the date)and a plastic bag filled with an absorbent type of material.Plus a lot of rusted metal debris,and a quarter sized hole in the sheet metal!And everything was damp.Picked up the connector with the green wire and the wire just fell out.Same with the other connector.No conn. at all with the green wire.Had a heck of a time seperating the connector,broke the clips off both,and I cannot get the broken piece of wiring out of the connector.New connectors?Or should I just try to ground it elsewhere?Now,even with the ground disconnected the map lights work when the dome light is on.Will having a good ground cause the map lights to work independently?Electrical is not one of my strong points.And inside the dome looks ok,2 srews for the 2 wires leading to the dome
and 1 screw holding the unit.
Thanks
Sudsrat
Go Fish!
Old Jun 1, 2003 | 11:43 PM
steve83's Avatar
steve83
Map Lights Work!
The 3rd screw in the dome light is the ground. Get some crimp butt connectors and reconnect all the wires, matching colors. Cut the original wires back until you see reasonably good copper. You may have to splice replacment wire in, so be sure to use stranded wire with oil-resistant insulation.
