Sponsored by: Auxito
2002 f150 4x4 problem
Old Oct 6, 2012 | 03:27 PM
mrrmerrill's Avatar
mrrmerrill
Very frusterated ...cant figure it out
4x4 wont work,when i shift the lever on the floor it doesnt engage so i bought two new soleniods..didnt help,have power on both solenoid conections
if i unhook my vacume lines frome the solenoid i can push the Actuator rod in making my 4x4 work
i,v gone threw everything..have vacume...have power on my solenoids..just nothin works when i shift into 4x4 on the floor
ANY ideas?????please
Old Oct 6, 2012 | 05:31 PM
Bluegrass 7's Avatar
Bluegrass 7
Well yeah.
You forgot all the other things that are involved with the system.
The lever has to signal the transfer case motor to run to the first position.
This turns a link rod in the transfer case to engage the front drive shaft and operates the 'High' solenoid to pull the actuator in and engage the front drive.
First check is the case motor runs.
Fuse to the motor is good etc.
It's way more than just relay operation in these trucks..
Good luck.
Old Oct 6, 2012 | 07:01 PM
mrrmerrill's Avatar
mrrmerrill
Thanks for the info but where is the case motor located and how is it checked?
i,v checked every fuse i could find
Old Oct 6, 2012 | 09:36 PM
Bluegrass 7
On the back of the transfer case.
It has a connector on it.
scottq
1978 - 1996 Big Bronco
25
Mar 14, 2025 10:35 AM
liv2roc
1997 - 2003 F150
Dec 14, 2018 04:50 PM
powerstroke973
Jan 27, 2015 12:33 AM
rbsample
Dec 9, 2011 05:42 PM
jem44357
Jan 27, 2010 09:13 AM
