WHEELS
Old Oct 6, 2012 | 05:58 AM
MarauderV8's Avatar
MarauderV8
WHEELS
short question, on my pick up truck is the combination 305/45-22 or, for winter the OEM w/ 18"!
now i want to have one from these rims with tires like they from the raptor with off road tires like in the attached picture. which size i have to choice?
It´s a F150 from 2005 FX4
[IMG]******** src='http://img521.imageshack.us/shareable/?i=kgrhqfjue56kv1boeyld2tq.jpg&p=tl' type='text/javascript'>*********><noscript></noscript>[/IMG]
Old Oct 6, 2012 | 09:24 AM
GwarForAll1021's Avatar
GwarForAll1021
Your picture doesnt work but I think I understand what your saying.
As long as your truck is the 6 lug and not the 7 that did come on some 04-05 trucks the factory raptor wheels will fit. Be careful because I don't know what rubber will fit on your truck!
Old Oct 6, 2012 | 01:55 PM
MarauderV8's Avatar
MarauderV8
thank you for answer, high value to know, that the wheels from raptor are fit!
the truck has the 6-lugs pattern! the most important is to know, which size i can drive with 18" and 22" that the has the look like picture!? (try to add a new one):
[IMG]
Uploaded with ImageShack.us[/IMG]
Old Oct 6, 2012 | 07:57 PM
GwarForAll1021
These are just my opinion I can be wrong and you can choose to do anything you wish. Just my advice.
With the factory stance I wouldn't go any bigger than 31s
With a 2.5-3 inch spacer lift you can go 33s maybe 35s but they will rub and possibly hit your finders going offroad.
With a 6 inch lift 35s will for just fine.
Important note!!! The more offset you use you have to either use a smaller tire or a taller lift.
The raptor wheels are more or less close to a standard offset. The HD monsters you have a picture would most likely have an offset.
Old Oct 7, 2012 | 05:16 AM
MarauderV8's Avatar
MarauderV8
do u know the factory size from a raptor?
Old Oct 7, 2012 | 07:49 AM
Coskid's Avatar
Coskid
Factory raptor wheels are 18". 20" wheels came on Fx4's, Lariat's, and King Ranch as an option and later more as the standard I think.
Old Oct 7, 2012 | 07:51 AM
Coskid's Avatar
Coskid
Also I have a 3" spacer on the front and run 285/65/18's which are basically 33". these tires will fit on a 1" spacer and in most cases on the stock height too. With a 3" spacer and some trimming 35" will fit.
Old Oct 7, 2012 | 09:11 AM
Still Smoking's Avatar
Still Smoking
With a 3" leveling kit I can fit I think they are 315/70/17 on Mickey Thompson classic II rims with no issue at all. They are like 35/12/17. But I have the same size tire but in nitro terra grappler on stock 18" fx4 runs and they rub
Xnorway
Jan 30, 2018 05:23 AM
2012 F250 6.2
Sep 28, 2017 09:08 PM
Irish19614x4
Feb 12, 2017 12:00 AM
mike330
Jan 28, 2008 06:15 AM
Johnnyboy04
2004 - 2008 F150
Nov 1, 2004 07:47 PM
