Antifreeze leak, need help!
Old Oct 4, 2012 | 07:34 AM
4CFarms's Avatar
4CFarms
I had been noticing that everytime i shut the truck off, it dripps antifreeze. Im not sure how to find the leak or something but if there is any possible way i can identify where its coming from, please help me. I can upload pics but im clueless on this one... any ideas welcome
Thanks
Old Oct 4, 2012 | 07:42 AM
gasman6674's Avatar
gasman6674
Check the thermostat neck and gasket, Its a common leak point. On mine the neck was rusted pretty bad and the gasket is a joke. Make sure you use some rtv when you put it back together.
Old Oct 4, 2012 | 08:20 AM
fordman67's Avatar
fordman67
Water pump! If antifreeze is dripping on the crank pulley.that is it.
Old Oct 4, 2012 | 10:39 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Both possibilties are right and more common. Look at the neck of the thermostat and look for the classic green salt there, if its clean, I bet its the WP Also check the clamps in the hoses.
Old Oct 4, 2012 | 12:01 PM
BuckHammer's Avatar
BuckHammer
Yes. Check your water pump.
Old Oct 4, 2012 | 12:11 PM
fordman67's Avatar
fordman67
I just did mine.not leaking but the bearings were getting loose.might as well do it before it left me stranded...
Old Oct 4, 2012 | 12:12 PM
BuckHammer's Avatar
BuckHammer
I think I did mine about the same time you did. Mine was like misting out, which I thought was weird, and the bearing was as loose as a [insert crude joke here].
Old Oct 5, 2012 | 06:18 PM
4CFarms's Avatar
4CFarms
i replaced the water pump and thermostat middle summer, so i think that the problem. im going to give it a check and thanks for the help. will give update soon, fingers crossed i just needed to tighten 1 bolt!
Old Oct 5, 2012 | 06:40 PM
4CFarms's Avatar
4CFarms
ok just checked. all hoses and conections to the water pump and stat is tight and no leaking. the leaking is coming from what seems to be on the rear of the engine and begining of the transmission. Is there a trans cooling pump there or whats the deal with a leak there???
Old Oct 5, 2012 | 06:47 PM
BuckHammer's Avatar
BuckHammer
Removed because I typed the response and posted prior to reading the post above this one - contained information that is now irrelevant.
Old Oct 5, 2012 | 06:49 PM
BuckHammer's Avatar
BuckHammer
Could it be leaking from a block plug and running down the back of the engine?
Old Oct 5, 2012 | 07:59 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Oil cooler?
Old Oct 5, 2012 | 09:23 PM
BuckHammer's Avatar
BuckHammer
There's another possible leak source. Good call, Jose.
Old Oct 5, 2012 | 09:42 PM
fordpride's Avatar
fordpride
Go to autozone and rent a coolant pressure tester. Pressurize the coolant system and look for leak
Old Oct 14, 2012 | 05:31 PM
4CFarms's Avatar
4CFarms
ok guys, i took it to my boys at the shop and they pressurized it and saw no leaks anywherre. the only thing they concluded was that there are freeze plugs on the rear of the engine, but the only way to place them is to pull the tranny or transfer case. does this seem probable to you guys, i just dont want to spend a lot of money for nothing
