View Poll Results: what heads are on my truck?????
what will swap in place of stock
100.00%
are mustang heads the same
0%
is a valve job a better option
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Cylinder Heads
Old May 18, 2003 | 11:55 AM
mytpnkn's Avatar
mytpnkn
Question Cylinder Heads
I just purchased a 93' 150. I am pretty sure that I need a valve job but I am wondering if a set of heads off e bay would be an alternate route worth going down. What I really need to know though, is what heads are on the truck. It is a 93 5.0 4X4 with an automatic overdrive trans. Any help would be greatly appreciated. This is the fourth F150 I have owned and the first 4X4 5.0. Thanks in advance.
Old May 19, 2003 | 02:32 AM
brian_06328's Avatar
brian_06328
Cylinder Heads
Your cylinder heads are the same iron heads that Ford used on the 5.0 Mustangs from '87-'95 and in the 5.0/5.8 trucks from '87-'96. They are restricitive as far as breathing goes and have 1.78" intake and 1.48" exhaust valves.
I would suggest you upgrade to something that will flow air a bit better for you. I got a pair of Trick Flow Twisted Wedge heads for my Bronco (can you tell I had the motor done on my truck BEFORE I got married?) They were expensive, but man that thing revs nicely
Old May 19, 2003 | 10:53 AM
mytpnkn's Avatar
mytpnkn
Wink Cylinder Heads
Thanks man. I just found out that my dad has a set of 95 truck heads that have 15000 miles on them. I think that the info you gave me will make the decision better. I also am married and since I got this truck during marriage the twisted wedge heads are pretty much out of the question
Old May 20, 2003 | 03:35 PM
jrocco's Avatar
jrocco
Cylinder Heads
Why don't you consider the GT40P performance heads from Ford.
They have 60cc combustion chambers and 1.84/1.55 Valves.
You can get them for about $240.00 each complete.
Flow numbers are very good for this head.
flow int 182 CFM @ .500, exh 121 CFM @ .500 (stock)
The combustion chamber is shaped for "clean burn"
See the following link for a lot of info on these heads.
http://www.geocities.com/motorcitymustang/gt40p.html
