'92 Driver door handle doesn't work
Old May 18, 2003 | 09:18 AM
Marc150's Avatar
Marc150
The outside handle on the driver door of my '92 F-150 doesn't work. We took the panel off and see what the problem is. When I push the outside handle button in, nothing happens. We believe the rod connecting it to the door latch is frozen op with rust. Is there a way to repair this without replacing the whole door?
Old May 18, 2003 | 03:47 PM
fjones's Avatar
fjones
My '92 F-150 had the same problem a couple of years ago. It was a broken cable between the door handle and door latch. I purchased the new cable from a local Ford dealer.
Old May 18, 2003 | 11:54 PM
steve83's Avatar
steve83
fjones is talking about the INside handle. For the outside, just follow the operating rod down to the latch mechanism. It's retained by a Z-bend there. If you can't find it at the pushbutton, it's just a broken plastic clip (the most likely cause). It's the same as the ones you'll see in these photos.
Old May 19, 2003 | 09:33 AM
Marc150's Avatar
Marc150
Thanks for your help, but the rod is there, and when i push in on the outside button, the rod tries to go down, but it can't. I think it's stuck up with rust in the actual locking mechanism. i looked on the other door to see how it works, and is looks like it needs to be freed up. I soaked it in WD-40 and other rust busters this morning.
BocceMon
16
May 23, 2014 04:09 PM
mkmchu
Feb 23, 2014 01:29 PM
mike L
Dec 19, 2012 10:56 AM
fordguy55
Jul 9, 2010 09:54 AM
Adamjr
Sep 22, 2009 06:25 PM
