If I'm removing engine-what else should I do while it's out?
Old Oct 1, 2012 | 12:00 PM
74 F350 SCS's Avatar
74 F350 SCS
I am coming up with a plan to do some engine work on my 460 in the 74 F350 regular cab, SCS, 2WD w/C6. Pretty mint/clean with only 43K original miles. Primarily new carb, intake manifold relacement, new pre-72 timing chain, rear main seal, clean out oil plan/screen. While the engine is out, I plan on painting the block and cleaning up the engine compartment. My mechanic/friend has a small single bay shop/garage and we will be tackling this but I can't have it apart for long as this is how he makes his living and he doesn't have much space for the truck to just be sitting around for a long period of time. He has to work on other cars.
While the engine is out, what other "easy or smaller project" type preventative maintenance items might I consider doing that is convenient to get to. Example, perhaps replace the motor mounts? Suggestions?
Thanks,
Old Oct 1, 2012 | 12:36 PM
HIO Silver's Avatar
HIO Silver
Given their age and the relatively low mileage, consider replacing the freeze plugs.
Motor mounts! ...Oil pan gasket... sounds like you were gonna do that anyway.
Old Oct 1, 2012 | 02:48 PM
J ballan's Avatar
J ballan
Torque converter seal.
Old Oct 1, 2012 | 06:14 PM
V10man's Avatar
V10man
Rear main seal. Maybe reorganize the wires. Clean up the engine bay.
Old Oct 1, 2012 | 07:53 PM
kevin316's Avatar
kevin316
Suspension rubber, body mounts. There is a lot of room to do that stuff with the engine out.
Old Oct 1, 2012 | 08:21 PM
Blue and White's Avatar
Blue and White
A good pressure wash/scrub of the engine compartment and front frame rails. If you don't have time to re-paint, at least touch up. For the frame, if you can get the grease and loose rust off, a brush coat of Eastwood rust encapsulator will help preserve them. A top coat of SG black Rustoleum if you have time.
mzavenm
Mar 24, 2019 12:28 PM
daggerNC
Nov 1, 2006 11:42 PM
elrodney
Oct 11, 2006 08:08 PM
zirkdog420
1978 - 1996 Big Bronco
Apr 11, 2003 04:56 PM
bigtoe
Jan 20, 2002 01:08 AM
