Guys I have a 95 f150 4wd standard cab short bed
I just put a leveling kit on the front end and it has the wheels way out of whack
Took it in for an alignment and was told I need 4 degree or larger shims to get her back with tires flat on the ground instead of pitched out from the top as they currently are .I'm sure someone on here has dealt with this same problem
The front end just had all the upper and lower ball joints replaced also
Same place the alignment shop will order them from: the local parts store.
Only difference if you pick them up yourself is that you won't pay the shop's markup.
