a/c vents
Old May 17, 2003 | 11:53 PM
omni's Avatar
omni
a/c vents
On my 1991 f-150. I was using the vent setting on my temp control the other day, and now when I set it to floor or defrost, I still get what seems like out side air coming out of the a/c vents, could a vacuum hose be off? the only thing I did out of the ordinary was swap out my radio, and when I put it back in it was a little struggle, could I have knock off a vac hose? any clues on this one? thanks
Old May 18, 2003 | 11:38 PM
steve83's Avatar
steve83
a/c vents
Yes, you could have unhooked or broken something. But 'floor' & 'defrost' (and everything else except 'Max A/C') normally pull outside air, so that's not a problem.
Old May 19, 2003 | 12:33 AM
omni's Avatar
omni
a/c vents
so if I have the defrost on or floor could I get alittle air out of the a/c vents aswell, maybe it was always like that I just picked up on it the other day and thought it was strange, I took my radio back out and all the vacuum lines seem to be in place, I activated the lever for floor to defrost and the little vacuum pots were working,
