Offroad & 4x4
Driving Tricks?
Old Oct 9, 2012 | 11:40 AM
  #31
dixie460's Avatar
dixie460
Which auto trans you have? A trick I use sometimes (mainly when I had my 2wd longbed F-250) is shift to manual second gear. Just put the lever in 2 and roll into the throttle real easy. The higher gear allows the engine to rev more (more converter slippage) before the tires begin turning.
Only works on Fords, by the way. Chevy/Chrysler transmissions start in first gear no matter if you shift to manual second or not.
Also, if you're offroad, you can let air out of your tires to get more contact with the ground. Don't drive on the street with low air though, always air back up once you get back to hard road.
Another trick... if you're pushing mud with your front wheels you can work the wheel left and right to clear a path for the front tires.
Old Oct 9, 2012 | 05:01 PM
  #32
77mud's Avatar
77mud
why would i want to burn out my trans by starting off in second in mud??
Old Oct 10, 2012 | 10:47 AM
  #33
dixie460's Avatar
dixie460
I wouldn't do it in mud, just wet grass. Even so, unless you were doing it repeatedly it won't hurt the trans.
Old Oct 10, 2012 | 06:00 PM
  #34
77mud's Avatar
77mud
ehh im not gonna do it at all
Old Oct 15, 2012 | 12:22 AM
  #35
87fordtractorwheeler's Avatar
i was jus going through the thread and i hav the same problem i got a longbed 87 f150 4x4 nd wat is a mini spool smokenchoken?
Old Oct 15, 2012 | 12:40 AM
  #36
alpha/omega's Avatar
alpha/omega
Its a little chunk of metal about as big as a baseball that replaces the spider gears in your carrier for positive traction. Basically the cheapest store bought locker you can buy. One for a 9" with the chromo center pin is like $50
Old Oct 15, 2012 | 08:22 AM
  #37
77mud's Avatar
77mud
Im not on top of the prices but i bought one bout 4 years ago and it was like 28 shipped to me
Old Oct 15, 2012 | 08:34 AM
  #38
alpha/omega
The chromo pin is another $15 or so.
Old Oct 15, 2012 | 10:24 AM
  #39
460 FORD MAN's Avatar
460 FORD MAN
Whats a chromo pin? And where are are they for 50 bucks?
Old Oct 15, 2012 | 12:10 PM
  #40
77mud's Avatar
77mud
Kris that was 28 with the cromo pin.
I wanna say i got mine from accuautoparts.com... at the time they were the same price for the mini spool and cromo pin as Randy's was for the mini spool and stock pin
Old Oct 15, 2012 | 12:15 PM
  #41
77mud's Avatar
77mud
I just looked a mini spool was 20 bucks on there site but didnt mention anything about what pin it was
EDIT: Just checked randy's and he wants 30 for the mini spool and 25 for the cromo pin
Old Oct 16, 2012 | 12:42 AM
  #42
460 FORD MAN
Damn thats pretty cheap. Thats all you need?
Old Oct 16, 2012 | 06:30 AM
  #43
alpha/omega
Youll also need a couple qts of gear oil and some rtv but yes.
I think we got the spool and pin from JBG. Places like Summit or Jegs or pretty much every race or axle supply store will have mini spools for 9" axles and I doubt quality is better for one brand versus the other
Old Oct 16, 2012 | 09:11 AM
  #44
mafia_jon's Avatar
mafia_jon
you can find a limited slip for cheap.. look on cl.
Old Oct 16, 2012 | 09:40 AM
  #45
460 FORD MAN
I got all that so i guess all I need is the spool and pin.
