timing problem
Old May 17, 2003 | 05:51 PM
charlie lines's Avatar
charlie lines
timing problem
I am trying to check my timing with an advanced timing light and when I turn it on the pointer marks on the crankshaft pulley isn't even close to the timing marks but show up at the bottom of the engine. what am I doing wrong?
Old May 17, 2003 | 06:01 PM
laka's Avatar
laka
timing problem
Do you have your SPOUT connection disconnected? You need to have it disconnected to set the timing correctly.
Old May 17, 2003 | 06:04 PM
charlie lines
timing problem
yes the spout is unplugged
Old May 17, 2003 | 06:20 PM
Bob Ayers's Avatar
Bob Ayers
timing problem
Are you sure you have your timing light connected to cylinder#1?
Welcome to FTE!!!
Old May 17, 2003 | 06:25 PM
charlie lines
timing problem
I have the light connected to the right plug wire but could i have the wire in the wrong place on the distributor?
Old May 17, 2003 | 06:31 PM
Bob Ayers's Avatar
Bob Ayers
timing problem
If the plug wires are off that far, you should be having trouble
with it starting, and running....Is it running real bad???
Old May 17, 2003 | 06:35 PM
charlie lines
timing problem
It doesn't seem to be but yesterday it started trying to stall and that is why I think the timing is off.
Old May 17, 2003 | 07:51 PM
Racerguy's Avatar
Racerguy
timing problem
If you're positive that you have the timing light lead on #1 plug wire (or #6 if it's easier to get at...yes #6 works too), the outer ring on the balancer could have spun which is making the marks no where close to where they should be.
Old May 17, 2003 | 08:19 PM
charlie lines
timing problem
Dear Racerguy
That makes a lot of sense, but what should I do next?
Old May 17, 2003 | 09:06 PM
Racerguy's Avatar
Racerguy
timing problem
You could pull the balancer off and compare it to a known good one or maybe just try bringing #1 piston up to Top Dead Center and see where the timing marks line up. The keyway in the crank will be straight up when #1 is at TDC. If you remove the balancer bolt and washer you can see the keyway. At least you'd have an idea then if that was the problem. If it seemed to be, you could replace the balncer.
