EGT's
Old Sep 25, 2012 | 09:13 AM
mojoman's Avatar
mojoman
Question EGT's
Hello folks...my question today is in the title....kinda...I run a '95 F250 auto 4x4 with 270 miles and a 6637 intake and 3" dp....will be towing a new to me travel trailer...its about 27 ft...an older model.....will be traveling in the interior of BC up some pretty long hills...will I need to watch anything...I have no gauges at the moment....thanks guys!!
Old Sep 25, 2012 | 09:46 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Well with that milage (270 miles) I first wait for the motor brake in LOL, then if its stock (no chip, no sticks, etc) I would not worry, this beast were made to tow IMHO.
But I surely install some gauges ASAP to peace in mind.
Old Sep 25, 2012 | 08:54 PM
mojoman's Avatar
mojoman
thanks...and gauges are in the future...then a chip....have stage 1's a year old...inch by inch...)
Old Sep 25, 2012 | 09:06 PM
fordpride's Avatar
fordpride
If its still stock tuning you won't see 1100* unless you got some boost and Uppipe leaks
Old Sep 25, 2012 | 10:32 PM
oldbird1965's Avatar
oldbird1965
Still have the stock downpipe?
Old Sep 26, 2012 | 09:17 AM
mojoman's Avatar
mojoman
3" dp...ten characters...
Old Sep 26, 2012 | 09:39 AM
oldbird1965
Good, you shouldn't have any problems, like Mike said.
You should however make it a priority to get a EGT gauge. Its my number one gauge I stare at going up hills!
Old Sep 26, 2012 | 01:28 PM
mojoman's Avatar
mojoman
thanks....another question....lower RPM uphill...or keep the revs up????
Old Sep 26, 2012 | 01:50 PM
richdawg's Avatar
richdawg
I would say keep the rpm's up. I don't think the turbo really starts working good till you get to 22 or 23000 and that will give more power and keep help keep EGT's a little lower. That's just what I have experienced, also shift down when needed and if you have an auto trans keep it out of OD on any incline.
Old Sep 26, 2012 | 05:53 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Yes I also mentioned that above.
Rich 22 or 23000 is a wide range, dont you think?
And of course RPM up.
Old Sep 26, 2012 | 07:23 PM
oldbird1965
If I loss speed on a hill and drop down to about 62mph I kick it out of overdrive. A steep hill about 45mph I'll drop into second with my auto.
Old Sep 26, 2012 | 07:26 PM
richdawg's Avatar
richdawg
Jose, a zero is still zero
mojoman, please don't take it to 23 thousand you could do damage to your engine
Old Sep 26, 2012 | 08:40 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
I dont want to hijack but when I loss speed on a hill, if I kick out of the overdrive, the truck doesnt do anything, even with the pedal in the floor and if I drop into second manually, same thing, the engine doesnt increase the revs, do you have any thought about this? This is pulling my TT (6-7k)
Old Sep 26, 2012 | 11:05 PM
oldbird1965
That doesn't make any sense Jose! You can't downshift, even manually or with the OT button? How does it shift starting out and gaining speed?
Old Sep 27, 2012 | 04:13 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Definitely keep the RPM's high when pulling grades. On long steep grades with a heavy load im even with the big boy trucks in the slow lane sometimes.
