engine starting question(wiring)
Old May 17, 2003 | 09:23 AM
78blueford's Avatar
78blueford
I have a 1978 supercab 4x4 frame ,engine(400)all the drive train
I was told the motor runs and I need to know what I would have to do to get it to start The engine wire harness is all their .Everything was unpluged from with fire wall so this is all the wiring that I have to work with
Anyinfo would be great thanks
78blueford
Old May 17, 2003 | 07:06 PM
Mil1ion's Avatar
Mil1ion
Can you provide photos of this?
Old May 18, 2003 | 01:31 AM
78blueford's Avatar
78blueford
Exactaly what pictures do you want , Just pics of the motor,and wiring or the hole rig
I can take some pics on sunday morning and see if I can get them on the site maybe sunday afternoon
thanks
78blueford
Old May 18, 2003 | 01:51 PM
Mil1ion's Avatar
Mil1ion
Just The wiring harnesses & connections in question.
There are two coming out the firewall behind the fuse box unless you have cruise control & a camper special.
Old May 18, 2003 | 03:04 PM
78blueford's Avatar
78blueford
I got the engine running today I took a 12v wire to the coil , then ran a 12v to the red wire on the two prong plug on the ignition module jumped a wire across the solenoid and she fired right up
I got some info from 73Custom and he was right
the motor started right up and runs great It has a few oil leaks but i think I got a good deal
the 4x4 works motor runs and I gave him a $100.00 for it
thanks
for the help I am sure I will be back with some more questions
here is the pic
it is a little late
