maf conversion need help
Old Sep 26, 2012 | 12:17 PM
Conanski's Avatar
Conanski
If you get the Explorer motor you won't be using the Explorer computer or any of the wiring that comes with it.. unless you want to make this project REAL complicated. Yes the Explorer is mass air but it's also OBD-2 and the transmission is computer controlled so there would be a whole lot of re-wiring and a rigging of things just to get the computer to run decent enough without that transmission attached. And besides.. the Explorer motor will run on the truck EFI system and YES it'll make more power than what you have now. However I'd suggest you strip it down to the longblock and install the truck intake, timing cover and water pump and accessory brackets and pulleys, all those parts from the Explorer are not compatible with a truck install.
Old Sep 28, 2012 | 12:47 PM
f1001969mike's Avatar
f1001969mike
forget it exploder motor is toast, heads might be usable, but i dont think anything else is, so i got a harness out of an 88 f150 for 10 bucks gonna do the re-wire
Old Sep 28, 2012 | 03:55 PM
UNTAMND's Avatar
UNTAMND
Gonna rewire what.
An 88 doesn't have any wires you need to convert to maf.
Unless you have a maf plug already, you're going to need one.
And you could have cut your existing injector harness to add longer wires from injectors to ecu. All I can think of needing a complete harness for would be to cut wires out from ecu plug and add pins to your existing one for injectors and misc stuff.
I don't understand what you're going to rewire with the 88 harness.
Old Sep 28, 2012 | 09:36 PM
Puddy's Avatar
Puddy
Headin home as we speak, I'll photocopy the directions for ya. Be up tomorrow.
solidrunner
Nov 2, 2006 06:11 PM
RKG
Mar 22, 2006 06:39 PM
TigerDan
Jun 1, 2005 06:46 PM
MORTORQUE
1978 - 1996 Big Bronco
Aug 14, 2004 10:29 PM
Hiflyer746
May 31, 2004 04:24 PM
