Help me diagnose a high RPM whine
These are a pain to find. Absent suggestions from anyone else, I'd start by taking the serpentine belt off and looking at everything connected to it. If the water pump is leaking, at all, through the weep hole, or is just old enough to perhaps warrant replacement, you may just start there. Check for any play or grinding in the alternator and idler pulley, too.
Mark
Mark
Any progress on this?
My truck was doing the same thing and removing the belt didn't quiet anything down. Tightened up the exhaust flanges and turbo connector to Y pipe. It quieted down slightly but would still make that horrible sound above 1900 rpms.
Last Saturday I hauled my 5th wheel over the mountains to Pahrump Nevada. On the way there we were traveling some wavy road service and the sound suddenly went away. It came back and then went away again. I told my wife that it must be an exhaust leak and the rough road is causing enough movement to silence it.
A few miles more and the sound changed dramatically. It was as though a piece of an exhaust gasket blew out and squealing chirping sound ceased. We could hear the exhaust leak but it was much more tolerable than that high pitched squealing.
My plan now is to order some new exhaust manifold and connector gaskets and tear into it.
You can clean them up , ford does offer a gasket set for them and I believe its for this exact reason. Ive worked on alot of 7.3ls and I have always tightened the manifolds up, especially on driver side rear they come loose fairly often. Mine comes in at 1900 rpm as well and continues through the power band and even on the declaration but as of late since I hauled that equipment it seemed to have stopped. I know there is an issue but man is it nice to not have the sound anymore and have everybody call me insane. It might look like a big job but its seems pretty easy for the most part.
tykateexcursion
1997-2006 Expedition & Navigator
11-27-2012 10:02 PM
tradosaurus
02-23-2007 07:37 AM
