injector question
Old Sep 23, 2012 | 05:45 AM
kupiec20's Avatar
kupiec20
injector question
my truck has 258k......and jim did stage 2's at 225k.
any ideas of what the problem may be.
1. at start up there is blue smoke whether the truck is warm or cold.
2. i noticed the truck start to get a little shake at idle when id get off a hwy.
3. now when i accelarate there is major missing with blueish white smoke.
the truck does have eletric fuel and the preasure is reading 52 psi.
good luck
Old Sep 23, 2012 | 05:48 AM
kupiec20's Avatar
kupiec20
would a bad VCH cause blue/white smoke
Old Sep 23, 2012 | 10:24 AM
Talyn's Avatar
Talyn
Check your down pipe for oil.
Oil leaks pre turbo are black smoke, oil leaks post turbo are blue/white.
There is always a possibility that you have an O-ring issue on the injector or a cracked injector cup.
I'd pull the VC's and check the harnesses, and check the injector hold down bolts for torque.
Old Sep 23, 2012 | 01:56 PM
kupiec20's Avatar
kupiec20
so is it possible with ONLY 28,000 mile on the stage 2's to be an oring! how is that possible?
Old Sep 23, 2012 | 02:48 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Couldve been unseated or pinched during install.
Old Sep 24, 2012 | 04:53 AM
kupiec20's Avatar
kupiec20
is it ok to drive until i figure this out.
Old Sep 24, 2012 | 05:37 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
How does it run with NO chip installed? Not a stock setting, but NO chip?
If you have not tried that, give it a shot and let us know.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Sep 24, 2012 | 07:15 PM
Ford4Life7.3
OT sorta but ice posted 3 comments on this thread in the last 2 days and only 1 is showing. Anyone else having this issue?
Old Sep 24, 2012 | 07:35 PM
kupiec20's Avatar
kupiec20
well im stuck on the hwy rite now.... it just bogged down and shut off on me. now wont start. when i try to start it the tac move. so im waitn for a tow rite now. i need help plz
Old Sep 24, 2012 | 07:44 PM
Ford4Life7.3
Did you ever check your vch's? I just had another burn up last night and it smoked and missed pretty bad, white smoke and injector knocking, because i had 2 bad harnesses. So check those
Old Sep 24, 2012 | 07:45 PM
pavementpounder96's Avatar
pavementpounder96
bet you blew your turbo. check your oil level. I had the same problem. I ran the **** out of stage 2s and chip with 3 inch down and 6637 airfilter and that turbo would squeel. then one day came the white blue smoke and have to add a 5 qt jug every 500 miles.
Old Sep 24, 2012 | 07:46 PM
kupiec20's Avatar
kupiec20
any idea why it just shut off...still waitn for a tow. lets chat
Old Sep 24, 2012 | 07:48 PM
kupiec20's Avatar
kupiec20
oil level was perfect....
Old Sep 24, 2012 | 07:50 PM
Ford4Life7.3
Go check your vch's while you wait
Old Sep 24, 2012 | 08:13 PM
pavementpounder96
could be the chip also. I remeber trying to get my chip installed and it would start and do funny stuff like that till I got the connections cleaned off really good. mine would rattle and then I would get cel and rough idle and sometimes no start after cleaning off the chip connection she ran great. I did it like 3 times till it ran right.
