1988 F150 Lift
Old 09-21-2012, 09:45 PM
aberg0812's Avatar
aberg0812
aberg0812 is offline
Question 1988 F150 Lift
I have a 1988 F150 Supercab Longbed. I want to lift it, but because of the length of it, I dont know if I want a 4", 6", or 8". I dont know what would look better. I will decide tire size by what lift I chose. Please reply with opinions, and pics of this model lifted if you have any. Thanks.
Old 09-21-2012, 09:59 PM
Shwan_89HD's Avatar
Shwan_89HD
Shwan_89HD is offline
Id go with a six inch lift, my friend has a 89 F150 supercab and has a 6 inch lift with 35 bfg KM2 tires and looks sick! I myself am gonna put a 6 inch lift on my 89 F250 regular cab
Old 09-22-2012, 05:56 AM
garthneddy's Avatar
garthneddy
garthneddy is offline
Make sure you add some bracing to the crossmember where the drop brackets bolt to. If you dont it will crack. Or you could just get some cut and turned beams and not worry about it.
Old 09-22-2012, 11:28 AM
burnout400m's Avatar
burnout400m
burnout400m is offline
First thing's first. What do you want to do with the truck? Small lift and tires is less work and the truck is still somewhat practical. Big lift and tires means lots of work, money, and maybe even fabrication to make it work plus it makes it a PITA to load it to do regular truck chores.
We would have to know what your plans for the truck are before we could suggest a route to take, the better idea we have of how the truck will be used the better advice we can give.
Old 09-22-2012, 07:07 PM
aberg0812's Avatar
aberg0812
Do you have pics of your friends truck by chance?
Old 09-22-2012, 07:08 PM
aberg0812's Avatar
aberg0812
Thanks for the advise.
Old 09-22-2012, 07:10 PM
aberg0812's Avatar
aberg0812
I want it somewhat practical. But I want it to look beefy as well, it looks too small right now because it is so long and so low. It might be offroading on some simple trails, I need just enough ground clearance to get over dips, small logs, stuff like that. But its mainly for show.
Old 09-22-2012, 07:19 PM
burnout400m
I would say 4" of lift and 35" tires is about the most you want. That will raise the truck a total of six inches off the ground so hopefully it'll still be easy enough to actually do stuff with but will give you more than enough off road ability. You will have to re-gear though.
Old 09-22-2012, 09:30 PM
aberg0812's Avatar
aberg0812
Yeah, that sounds about right. I do want to see if anyone has pictures of my model with that lift just because i am not sure how it would look because of the truck's length.Thanks
bluemtn95ford
34
09-27-2013 04:16 PM
redneckford02
1997 - 2003 F150
10-29-2010 09:03 PM
vee78f250
10-26-2004 10:59 AM
goingup
04-07-2003 10:28 AM
jbooker82
Offroad & 4x4
03-02-2003 04:15 PM
Quick Reply: 1988 F150 Lift
