6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
ok so which is it?
Old Sep 23, 2012 | 12:06 PM
wp6529's Avatar
wp6529
Originally Posted by slowmans
I am going to agree to disagree here.....many who are "stock" just drive the truck and have plenty of dilution , its not a requirement to let your truck finish the regen process. Those of us who know better may have similar results as you but I am sure there are plenty of people who take relatively good care of their truck and have high dilution rates. I never started sampling until i was deleted so i cant say, but I do know that I have had less than half a percent of fuel if any.
Lots will say that Bio will make fuel dilution worse, in stock form this may be so but i run B-20 religiously and have been for 10,000+ miles with no ill results and my UOA's are great! I do think there are many factors that come into play here so each truck will vary.
The new generation of diesels are pretty much light years appart technology wise from the old generation of diesels. There are a great many benefits that come with electronic fuel injection and variable geometry turbos, but they also come with a requirement for a higher level of maintenance.
I don't specifically run bio, but I know I've had a number of loads of bio blends while doing some trips between TX and CT and they have not made any discernable difference in the UOAs, so I don't think bio is an issue fuel dilution wise. So far the only thing I've seen give notable fuel dilution is interrupted regens.
99expyTN
Aug 26, 2014 05:58 AM
Vinford
Jan 9, 2013 05:04 AM
Terry SD
Nov 22, 2012 10:42 PM
HVAClawson
Oct 28, 2012 05:39 AM
bluefishgary
Oct 1, 2012 12:16 PM
