Transmission Troubles
Old May 16, 2003 | 05:10 PM
Colossus's Avatar
Colossus
I have a 1979 Ford F350, C6 automatic. The transmission was rebuilt about 10,000 miles ago (truck has 70,000 orig). My question is about the transmission fluid. Now, I have read that new tranny fluid is bright red, mine appears to be a golden color, looks like brand new 10w-30 oil, it smells like ATF, but I don't think its burnt. Is it possible that this is a different kind of tranny fluid? Or is it the wrong kind altogether?
Old May 16, 2003 | 08:28 PM
steve83's Avatar
steve83
Sounds like it might be Type F.
Old May 16, 2003 | 09:10 PM
Colossus's Avatar
Colossus
Darn...that thing is supposed to take Dextron II. You think I should call the shop (its there right now for other problems - Check it out 73-79 Forum - F350 Problem Child) and have them change it out?
Old May 17, 2003 | 09:36 PM
steve83's Avatar
steve83
Yeah, see what they think.
Old May 17, 2003 | 11:11 PM
Colossus's Avatar
Colossus
I'll make a note of it so I can tell them monday. Thanks.
Old May 17, 2003 | 11:50 PM
Boss_358's Avatar
Boss_358
I could swear that dexron and type F are both red. What about that mineral or organic stuff that the foreign cars use? I have not seen what that stuff looks like. I know that my friends 2000 ram takes this stuff. I guess that stuff is not cheap either. Any time an older type F tranny is rebuilt it should take Dexron/Mercon, or at least this is how it has been. I had a 77 C6 rebuilt and the shop owner told me why this is. I think it was something to do with the clutches. Type F will eventually be obsolete. Just like leaded gas and R-12. Who knows what will come next. Probably that expensive stuff.
Old May 19, 2003 | 02:25 PM
Momudder720's Avatar
Momudder720
Sounds like a good time to start buying a case a week from the local Napa. By the way, how can you tell if you've burnt your tranny fluid? Mine also is still red, but I know my tranny got a bit warm this weekend at the mud bog and just wanted to make sure I didn't burn anything up. I could put my hand on the cooler and filter (external kit from B & M) and could hold it there for a few seconds before it got too much for me to handle. Gotta get a fan for that cooler and a trans temp gauge is in the process...
Old May 19, 2003 | 03:11 PM
Colossus's Avatar
Colossus
There is an article in the most recent Popular Mechanics that shows you how to check your transmission fluid and how to change it. Thought this might help.
