Bolt pattern?
Old Sep 19, 2012 | 08:49 PM
4x4fordf150's Avatar
4x4fordf150
Bolt pattern?
Hey guys, My dad has a 2001 f350 that he has a set of aftermarket wheels for which he doesn't use and i have a 1990 f250 and was wondering if i could mount his wheels on my truck. same bolt pattern?
thanks
Old Sep 19, 2012 | 09:05 PM
BlueMule's Avatar
BlueMule
thanks
Nope, the bolt circles are different sizes. Yours has a 6.5" bolt circle and his has 170mm (6.69") bolt circle.
Old Sep 19, 2012 | 09:17 PM
AP3X's Avatar
AP3X
You'll have to get spacer/adapters.
Old Sep 19, 2012 | 09:18 PM
4x4fordf150
Could i make them do you think?
Old Sep 19, 2012 | 09:21 PM
AP3X's Avatar
AP3X
Probably not. You could with a cnc machine or if you're damn good with a mill. Here's the first ones that come up on ebay:4 x | 1.5" | 8x6.5 to 8x170 | 8Lug | 14x1.5 Studs | Wheel Adapter Spacer | eBay
Basically you need an adapter for 8x6.5 to 8x170. The width of the spacer is your choice.
Old Sep 19, 2012 | 09:23 PM
raystankewitz's Avatar
raystankewitz
Don't even go there.
It's bad enough that most commercially made adapters are utter junk, I can't imagine how unsafe home-made adapters would be.
Find a set of wheels that you like and that have the correct bolt pattern.
Last edited by raystankewitz; Sep 19, 2012 at 09:43 PM. Reason: Hit send too quick and allowed cat on the keyboard, leaving out the word 'most'
4x4fordf150
Thanks, i am pretty clueless.
Old Sep 19, 2012 | 09:41 PM
raystankewitz
Close examination of those adapters shows the issue with almost all adapters. Instead of indexing the rim off of the center hub where the strength is, you're forcing the wheel to index off of the studs. Not good. This places the lug studs in shear. Besides, those adapters look like they're aluminum.
Arrowcraft is so far the only company that I know of that actually has lips on their machined steel adapters to index the wheel on the center hub. I've had a chance to see how they work (adapters plus the ten-lug adapters and 24.5 Alcoas on a truck almost identical to mine!), but I have to say, I'm not sure I would run them on my truck. Those big wheels/tires weigh quite a bit! By the way, these adapters are for dually conversions only.
Just some food for thought. YMMV.
Old Sep 19, 2012 | 09:49 PM
4x4fordf150
Thanks a ton.
diesel-fitter-bum01
Apr 26, 2011 04:07 PM
ZYDA
Jun 7, 2009 09:04 AM
Shanemh
Jan 15, 2007 09:22 PM
TxBandit
1997 - 2003 F150
Oct 8, 2003 04:28 PM
thoriak101
1997 - 2003 F150
Sep 14, 2002 12:23 PM
