Engine Rough, help please
The engine in my F150 has started running rough. Runs rough at speed, but seems to idle fine. I cannot distinguish if it is fuel or electrical. Here is what I have done to date. I have replaced the fuel filter, and the O2 sensor. The air filter is clean, and I added a bottle of fuel conditioner to remove any possible water in the tank. So far, none of these have helped. The "check engine" light does not come on. The dist cap, plugs, and wires were replaced about 6 months ago. I have not replaced the coil. Plugs and wires appear to be dry. Fuel pressure is 45 psi and vacuum is 21 inches.
Engine details: 1989, f150, 4.9l, 6 cyl, fi.
Thanks in advance for any comments or suggestions!
Stan
