steering column difference ?
Old Sep 18, 2012 | 03:36 PM
johnebgd's Avatar
johnebgd
hi can someone tell me the difference between a 69 f100 2wd and 4wd column ? my truck has been converted to p/s and I believe it has a shorter
4wd column in it and now I cannot find a directional switch for it
thanks John
Old Sep 18, 2012 | 05:45 PM
willowbilly3's Avatar
willowbilly3
I believe 2wd and 4wd use the same directional switch. What do you mean you can't "find" one? The one that's supposed to fit the truck doesn't?
Old Sep 18, 2012 | 06:18 PM
johnebgd's Avatar
johnebgd
switch problem
my problem is the plastic part that holds the horn spring contact is too high. when I removed the steering wheel to check why the horn was not working that part was broken off and the spring contact was missing. I replaced the switch and the steering wheel will not go down all the way. so I had to put the old broken switch back in. I have a grant steering wheel and tried 2 different adapters, both do not have enough clearance for the horn contact.
any info will be greatly apreciated
Old Sep 19, 2012 | 12:46 AM
willowbilly3
Who converted it? Maybe they cut the shaft instead of getting the correct shorter one and cut it too much. Or maybe they've got some jacked up mess at the bottom bearing that's keeping the shaft down too far, who knows? You might start by finding the proper steering shaft.
Old Sep 19, 2012 | 11:19 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
4wd column in it and now I cannot find a directional switch for it.
TWO different T/S switches used in 1969, 2WD/4WD makes no difference. The serial number is the last 6 digits of the VIN
C9TZ-13341-C .. T/S Switch / Available from Ford
1967/68 F100/350 / 1969 F100/350 before serial number G30,001.
DOTZ-13341-B .. T/S Switch / Obsolete / Available NOS
1969 F100/350 from serial number G30,001 / 1970/72 F100/350.
Horn doesn't work. On the outside of the steering wheel, visable when the button or ring is removed, is the horn brush and insulator (C2OZ-13A821-A).
Brush has a thin copper wire that snaps. People remove the steering wheel, either the brush or both parts fall out, usually unnoticed.
Then when steering wheel reinstalled, the horn no longer blows, people wonder why.
jsnbuck
May 3, 2013 10:08 AM
sgreen
Ford Truck Parts for Sale
Apr 5, 2012 03:26 PM
69 F100 Cali
Mar 25, 2012 09:39 PM
Sixoh
1947 and Older Ford Trucks
Jun 18, 2009 10:10 AM
dstruble
Jan 16, 2006 07:59 AM
